Question about Levers (pazzo/CRG/asv/etc)
Started by aa4111, December 13, 2008, 07:38:09 PM
aa4111
I have an S2R 800 with the coffin style master cylinders. If I buy levers now, but want to upgrade to radial mc's later, will I have to get new levers later as well? In other words does it matter if I have coffin style masters or radial masters when looking for levers?
DarkStaR
Quote from: aa4111 on December 13, 2008, 07:38:09 PM
It matters!!!
COWBOY
yes.  they attach differently.  your levers are even different than some monsters.
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
aa4111
Hmm guess Ill hold off on levers for now then... thanks guys
I just too ka peak on the pazzo site and they don't even seem to make levers for the coffin masters anyways.  CRG does make them though
But yeah to what cowboy said.  There's a lot of differences between your coffins and radial configuration masters.  Besides, if you get a set of the Brembo radials, the stock levers are adjustable.  You might find the stock radial levers suit your needs/signifigant improvement over the 620 stockers than you might back burner plans for a set of aftermarket levers.
