January 09, 2025, 01:08:17 AM
Please Help
Speedcell install and fuel line re-route
Topic: Speedcell install and fuel line re-route (Read 2907 times)
TAftonomos
is without a monster :(
December 19, 2008, 05:37:19 PM »
Just finished with the customer exhaust, time to do something for me
Got the speedcell batt in. No charger/maintenance needed either, so no trickle charger lead!
I used some closed cell foam from an Xbox warranty return to make sure it wasn't going anywhere. I'm retarded, I actually weighed different kinds of foam to find the lightest
After that, I turned my attention to the fuel lines. The testa is tightly packed. Both the pump and reg are inside the tank, so in/out orientation doesn't matter. Pulled the airbox, flipped the lines around on the injector (so they were facing left now). Fished them inbetween the battery and the ecu (TIGHT). Had to make them bend around the right side similar to stock to get them to the tank. I tried about 10 different ways, and that was the best (only) way so that the tank may be raised/lowered without any special handling.
The lines touch the valve cover for about 2-3", so I ran down to summit racing and picked up some DEI fire sleeve. Rated to 500 deg continuous exposure....if my valve cover gets half that hot I've got bigger problems anyway (bike on fire!).
Anyway, here are the pics:
MyDucParts.com
Capo
You Are What You Is
Re: Speedcell install and fuel line re-route
December 19, 2008, 05:56:24 PM »
Do you have the details for that battery? Thorsten Dubahn has three types.
Capo de tuti capi
TAftonomos
December 19, 2008, 06:37:43 PM »
240 cold cranking amps
Unaffected by cold weather above 35deg
Looses 3% of it's total capacity per year, WITHOUT being on a tender
No need to feed it.
Rated to 1000 starts
1lb 6.2 ounces
Starts my s4rs up just as quick/quicker than the stock fresh battery in the bike.
The speedcell has been sitting in my garage for 2 months now, waiting for me to get to it. It's not been on a charger of any kind, and it's been in the 40's for the past 3 weeks.
Price upon request, ordering a few on Monday
MyDucParts.com
CowboyBeebop
December 19, 2008, 06:45:55 PM »
Quote from: TAftonomos on December 19, 2008, 06:37:43 PM
No need to feed it.
1lb 6.2 ounces
I know very little about batteries. Can this be charged/tendered with a typical charger? Also, would different sized Monsters require a different battery? For example, I have a 620, but I'm thinking about upgrading to a 900. Would I need to buy a different battery?
TAftonomos
December 19, 2008, 06:58:05 PM »
Generally speaking, no. There is a lighter 9 ounce battery available, but with only 120cca's, I wouldn't recommend it for a street bike. Besides, 1lb 6 ounces is plenty light enough
(7lbs saved vs/ a typical "light" battery.
Once the bike is started, the battery does very little to actually run the electronics.
Race only applications, the 120cca battery would be fine, and will run a total loss electrical system for ~40mins with a typical fuel injection system draw on the batt.
YES, you can charge it no problem, but there really isn't a need to. Thats another one of the great things about the new battery technology that is coming to the market.
Speedcell advertises that you can put a fully charged battery on the shelf, and it will only loose 3% of it's total charge PER YEAR...without being on a tender.
MyDucParts.com
MonsterMan1036
December 20, 2008, 07:28:27 AM »
God, that battery is crazy small!!
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
DucHead
No garage queens
December 20, 2008, 07:37:48 AM »
Nice job Theo!! But where is the carbon fiber/titanium battery tray??!!
That battery is CRAZY small!!
"45"
TAftonomos
December 20, 2008, 12:06:00 PM »
CAUTION. My fuel line quick disconnects leaked and sprayed my leg with gas. They arn't properly locking on the cap, and something will have to be done.
I was able to get a short video, but I'm having some trouble uploading it to youtube (never done that before).
MyDucParts.com
DucHead
No garage queens
December 20, 2008, 12:14:36 PM »
Bad/misaligned o-ring?
"45"
MonsterMan1036
December 20, 2008, 01:48:18 PM »
TA, You probably already know this but I would shorten up your fire sleeve. Also, do those quick releases have o,rings? On the quick disconnects I use they have a small o'rings and tare very easily. Which caused gas to spray when the pump primes.
Alex Ortner 1036CS
1199 Tri
TAftonomos
December 20, 2008, 01:54:45 PM »
It's not leaking a bit, it BLOWS the fitting off when the pump pressurizes. The plastic clip isn't engaging the catch properly.
Sleeve shortened as well.
MyDucParts.com
scduc
December 20, 2008, 02:25:17 PM »
What is the life expectancy of these smaller batteries?
08' S2R 1K That was close damn near lost a $400 hand cart.
TAftonomos
December 20, 2008, 03:20:21 PM »
Rated to 1000 starts, will loose 3% of max charge per year.
Ought to last quite a long time IMHO. I'd guess 3-5 years isn't unreasonable at all. Perhaps a bunch longer depending on how often you ride.
Update on the fuel line connection. Got it to "stay" for now. Not going to ride until I either put the lines back on the right side (un-reloacte?) or go with plan B.
Plan B involves pulling the pump out of the tank. Welding up the plate. Drilling/tapping the holes for metal quick disconnects, and using those.
Probably go with plan B at this point. Seeing how weak and crappy those connections are right above the exhaust pipe has really pissed me off.
make the beast with two backs it, plan B just became plan A.
Last Edit: December 20, 2008, 03:22:52 PM by TAftonomos
MyDucParts.com
December 20, 2008, 03:59:01 PM »
I have disconnected the fuel lines on my 06 S2R1000 and had no problems with them reconnecting...
TAftonomos
Reply #14 on:
December 20, 2008, 05:34:23 PM »
Dunno what to say. It appears that the clip is deformed from pulling it off, and thus doesn't fully lock down.
Doesn't matter anyway, the thought of a fire under my ass at speed isn't something I ever want to have to wonder about.
After searching on ducati.ms for awhile, and seeing a few pics of burned hunks of metal/plastic/carbon that used to be ducati's, it's clear that plastic isn't an ideal solution for a fuel line connection. Thus, I will remidy ducati's shortcomings with something I don't have to worry about
Last Edit: December 20, 2008, 05:36:05 PM by TAftonomos
MyDucParts.com
