April 27, 2024, 04:04:50 AM
M-ROC
Rameses
Fiberglass fabrication
Topic: Fiberglass fabrication (Read 4935 times)
DucHead
No garage queens
December 21, 2008, 06:55:59 AM »
Does anyone know how to make small fiberglass parts? I've seen some things online that suggest that it's not
too
difficult.
"45"
superjohn
Re: Fiberglass fabrication
December 21, 2008, 01:10:58 PM »
I don't know enough to actually do it. From what I've read and seen in magazines you have to carve out a blank of the part you want, then make a mold off of that and form the part.
Maybe check with one of the car stereo shops. They make custom enclosures and dash panels quite a bit I think.
I'd like to check it out if you try it though.
Last Edit: December 21, 2008, 01:17:08 PM by superjohn
DucHead
No garage queens
December 22, 2008, 11:40:33 AM »
Quote from: superjohn on December 21, 2008, 01:10:58 PM
Thanks, John. I might just give it a go. I found a few videos on youtube. for the piece that I want to do, it looks like the procedure is to first make a fiberglass mold: wax the piece you want to make a mold of, spray with poly[vinyl alcohol], brush on resin, lay down fiberglass, more resin, more fiberglass...to the desired thickness. Then repeat the process to make the part. I'm going to look for a kit over the break.
"45"
Rameses
Moderator
*Your Mom* has a Hypermotard
December 22, 2008, 09:45:18 PM »
Quote from: pompetta on December 22, 2008, 11:40:33 AM
Yep, that's the procedure.
I've never done it myself, but I've done a good bit of reading on it (and cf layup as well), and talked to some people who've done it.
Sounds like making the plug and mold is the most difficult part.
Jobu
December 22, 2008, 11:41:50 PM »
Are you making a fiberglass mold of your penis for Donna for Christmas? I don't want anything to do with that.
superjohn
December 23, 2008, 05:21:50 AM »
Quote from: Jobu on December 22, 2008, 11:41:50 PM
Wasn't there a how-to video someone posted a while back on how to do that?
ncgt1000
December 23, 2008, 08:23:45 AM »
Quote from: superjohn on December 23, 2008, 05:21:50 AM
I am absolutely sure that I have never even thought of searching for such a video.
Still, an interesting DIY project no matter what D is attempting to make for himself (or whomever)!
Merry Christmas all.
'07 GT1000 - with mods of course
DucHead
No garage queens
December 23, 2008, 09:30:47 AM »
Nope, no penis fabrication.
What would be the point? The original is utter perfection.
Back on topic...I want to make a fiberglass version of my CF "dash." It needs to be cut down to accommodate the lowered gauges, and I don't want to cut the original item.
"45"
TiAvenger
December 23, 2008, 12:20:40 PM »
Quote from: pompetta on December 23, 2008, 09:30:47 AM
Why fiberglass, when you can use cf for a bit more?
Rameses
Moderator
December 23, 2008, 02:23:44 PM »
You're probably thinking of the video I posted in the funny video thread a while back.
It wasn't a mold/replica project. It was just a homemade dildo.
superjohn
December 23, 2008, 02:43:31 PM »
Quote from: Rameses on December 23, 2008, 02:23:44 PM
Oh yeah!!! That's the one.
DucHead
No garage queens
December 23, 2008, 07:11:51 PM »
Quote from: Court-Jester on December 23, 2008, 12:20:40 PM
I guess I could, but chopped mat is pretty cheap, and the part I have in mind is ornamental. That, and I want it black, not CF.
"45"
DucHead
No garage queens
December 23, 2008, 07:18:17 PM »
It appears that the most popular release agent is an aqueous solution of poly[vinyl alcohol] which is sprayed onto the mold and let to dry.
Does anyone (Rameses) know what weight percent solution is used?
Boy, finding small quantities of materials is a PITA. I'm going to try the boat place near my house. It also appears that I could buy a fiberglass repair kit (mat + resin) at Ace Hardware, and purchase release agent separately.
For the mold, I'm going to:
(1) shape a piece of modeling clay,
(2) lay cellophane over it,
(3) press the CF piece into the clay,
(4) remove the piece and the cellophane
then apply release agent, and lay up the fiberglass.
"45"
Rameses
Moderator
December 26, 2008, 10:35:04 PM »
Quote from: pompetta on December 23, 2008, 07:18:17 PM
No idea.
Sorry man.
DucHead
No garage queens
Reply #14 on:
December 27, 2008, 07:08:50 AM »
Quote from: Rameses on December 26, 2008, 10:35:04 PM
No idea.
Sorry man.
Time for a few experiments!
"45"
