January 08, 2025, 10:06:06 AM *
Author Topic: Bitubo Steering Damper Questions  (Read 1455 times)
DucSteve
Hey Yo
« on: December 25, 2008, 06:40:15 PM »
Just put on a Bitubo steering damper recently and had a few questions.
1) Can you actually tell much of a difference with it on while riding?  Since it's cold, I've only putted around town and whatnot, but even on hardest setting I barely notice it at all. I detached it to check and make sure it was working, by hand it is extremely harder to pull it in and out compared to lightest setting. I just hear people saying they set their dampers to lower settings for around town stuff cause it makes it too hard. Maybe because I have handlebars instead of clipons its just easier?
2) Did they grease it up like mad? Seems like they did. After a while some of the grease builds up and drips off a little. Maybe after a while the excess goes away, just seems odd
BellissiMoto
« Reply #1 on: December 25, 2008, 07:45:39 PM »
1. Makes one hell of a difference on my 1098, and I always wanted one back when I had my S4R. based on your description, your damper is working fine and You will truly notice the difference once your able to hit the gas, and that front wheel comes off the ground. With your damper you will be much safer from tankslappers, and your bars should stay relatively straight with no effort on your end required. A good damper will not be noticed when it is not needed.
2. I can't speak for yours, but every one I have received/installed/sold has been clean - no grease, but simply try wiping it off and see if it comes back, if it keeps coming back you may have a problem, but I don't know what it could be since these are gas charged dampers.
Ducnial
« Reply #2 on: December 25, 2008, 08:22:14 PM »
Easy Test..
At ~40mph bump one side of the handle bar enough to upset the bike s little.  w/o a damper the back end will wobble as it recovers,  w/ a damper you ought not feel it wobble.  A Damper will reduce steering response from actually turning the at the head tube and force more counter steer.  Might be you're using proper steering technique and wont notice much of a difference under "normal" conditions.  Beside reducing head shake when the front gets light, you'll really appreciate it when an unintentional road bump or chuck hole catches you off guard.  The other side of the coin is setting it too tight makes swerving to avoid obstacles more difficult/slower.  For round town I set mine pretty neutral and stiffen it up on the track.
Online Online
« Reply #3 on: December 25, 2008, 08:42:46 PM »
Your damper may be leaking.  The damper is hydraulic with a gas charge.  Clean, run through the stroke a few times and check.  If it is wet again, clean and try again.  The wet persists, you have a leak.  My Arrow has six adjustments.  At the firmest adjustment you can really feel the resistance at rest or low speed.
DucSteve
Hey Yo
« Reply #4 on: December 25, 2008, 10:14:10 PM »
Yea I'd clean it and it would be wet again after a few more strokes. This is exactly how I got it, seemed leaky before i even took it for a testride
