*Finished* Home Made Sprocket Cover and Chain Guards
Started by flanman, December 29, 2008, 10:41:32 AM
flanman
Just thought I would share my latest project with you guys. The idea came from the Moto Wheels cover I just pretty much made my own. Right now it doesn't have any paint on it... thinking about black, and it needs some cleaning up. I was looking into powdercoating/ home systems but for me right now a decent spray paint is going to have to do. Any recommendations?
IZ_ I know  :-\
teddy037.2
this piece is Islander Approved
[thumbsup]
what mat'l is it made of? looks fine as it is
flanman
Just sheet metal from Home Depot nothing fancy  :) I might just spray it with clear I kind of like the look of the metal. I plan on making same style pieces to replace the entire plastic chain guard. I just want to do it tastefully and not go overboard on the whole circle theme  ;D
teddy037.2
my only thought was corrosion... clear works  ;D
Jaman
herm
Quote from: flanman on December 29, 2008, 10:53:10 AM
i have been thinking about this for a while now...let me know how your progress goes [thumbsup]
Jarvicious
I don't know too much about gun care, but what about doing it in actual gun metal blue?  I agree though, it's gotta have some sort of finish or it will rust up on you pretty quick.  Or is it aluminum?
Nice work.  Just make sure you keep your laces tucked in  :).
mmakay
Quote from: Jarvicious on December 29, 2008, 09:35:50 PM
It's basically a black oxide finish.  It relies on a light film of oil to prevent additional "red oxide" from forming.
- Mickey
eichh
Nice work. [thumbsup] How did you make the clean bends on such a small piece?
flanman
Thanks for the feedback everyone I really appreciate it  [thumbsup] It is steel so it will rust. I finished sanding it with 220 grit paper yesterday and hand filed the edges. I would have liked to clear it but really wasn't sure how protective the choices were at my local paint store... So its semi flat black now with a rust protector paint. The bends were done with just a vice to make the initial angles followed by a little work with pliers and support pieces (to help keep the angles in place), with the help of a hammer every  now and then. Very trial and error it took a few tries to get it all fitted properly. I have the chain guard off... Didn't realize one of the little bolts holding it on won't come out all the way... It hits the footrest support right by the heelgaurd. Cut it loose and am working on templates.
flanman
So a little more progress on my project. Just finishing up the matching chain guard I need to sand it and think I am going to drill smaller holes in the back to remove more material. I painted the sprocket cover and don't really like it so either I am going to find a good clear or a Ti gray color or something that wouldn't be just another mismatched gray on the bike.
I will get around to taking a pic with it all on but for right now that's all.
DucHead
Cool!  Can you post/PM a template for the sprocket cover?  [beer]
Duc Fever
"You have not converted a man because you have silenced him" ~ John Morely
BastrdHK
#13
I don't see a pic?
Never mind......now my browser decides to work.
The do it yourself mods are infinitely rewarding 8)
M-ROCin' it!!!
herm
Quote from: flanman on January 07, 2009, 10:01:47 AM
how did you make the chain guard? special tools?
i assume its made of the same thing as the sprocket cover?
could the chain guard be made longer (say, the same length as the stocker...)
