which levers: pazzo or crg?
Started by mrplease, January 02, 2009, 08:53:59 AM
mrplease
i am going to order some brake/clutch levers today or tomorrow.
do you guys recommend the pazzos or some cgr roll-a-click levers?
if you guys have some pics to compare the two that would be great too...
jdubbs32584
I've got Pazzo shorties and I like them. Here's a couple pics:
I have them on the setting that allows them to be as close as possible to the bar. I have itty bitty hands.
Mine are CRG normal length, "titanium" finish
I found this link very helpful ESPECIALLY THE LAST PART ON ADJUSTING PROPERLY  I now have "immediate" action which allow me to adjust the levers closer to the bar, which result in a firmer/more controlable grip on the levers.     http://www.ducatisuite.com/leverchange.html
Statler
DarkStaR
duclvr
mmakay
They are basically clones of one another.  (No, I don't know which came first....)  You aren't likely to tell a difference without trying very hard.  Get whichever comes in the color you want for the least money.
- Mickey
AFAIK the CRGs came first but there really isn't all that much difference between them.  The Pazzos have a more jeweled like finish on the top and bottom of the lever where the CRGs don't.  The Pazzos are also available in many more colour combos (both lever and adjuster) where the CRGs are only available with red adjusters.
DarkStaR
wasn't there in issue with the CRG's not addressing the clutch switch on the coffin masters?
Quote from: DarkStaR on January 02, 2009, 01:06:12 PM
Not sure about that.  The CRGs on my Sport1000 have the clutch switch on them.  I think they might have revised their design a little while ago.
Yes.  There was (may still be) an issue that the CRG levers didn't have a tab to activate the switches on the bar.  People remedied this by making ones out of sheet metal.  But CRG might have updated their design now, to incorporate that.
And just for the record - CRG was 1st, and Pazzo basically cloned the CRG design.  Some people gave them guff for it.. but as far as 'knock offs' go, they are quality levers... I've got a set.
Desmostro
COWBOY
i have used crg and seen the pazzo's both are about the same (I preferred the feel/shape of the crgs).  that being said my next pair will be ASVs.
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
JEFF_H
the CRG's have the tab now, the part # for the new ones is AB-611
mrplease
now what are the main differences between the shorty and regular length? i know they are 1 1/4" shorter but why d people get short vs. long? besides the looks?
