January 09, 2025, 11:12:15 AM
Superbike fender rubbing?
Topic: Superbike fender rubbing? (Read 1160 times)
JTMOTO
January 03, 2009, 08:18:22 AM »
748 fender rubs bad on the back side. Is this normal or a bad fender? Anyone have fitment issues with thes in the past? Just installed it last night. and went to walk it backwards and heard the rubbing. This is what I bought
http://cgi.ebay.com/ebaymotors/DUCATI-748-916-996-998-CARBON-FIBER-FRONT-FENDER_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem380071360779QQitemZ380071360779QQptZMotorcyclesQ5fPartsQ5fAccessories
Last Edit: January 03, 2009, 08:39:41 AM by JTMOTO
teddy037.2
Re: Superbike fender rubbing?
January 03, 2009, 09:35:11 AM »
that seems new to me.
is it only rubbing on that very rear corner of the fender? you could always grind it down.
of course, taking much care when grinding CF (wear a respirator!)
DarkStaR
January 03, 2009, 10:21:59 AM »
I'd say bad part.
If that's how much you paid, you should return it and spend a bit more for a quality part.
FYI: The back portion of the 1098 front fender looks cleaner. IMO
JTMOTO
January 03, 2009, 10:25:02 AM »
Yeah I knew it was too good to be true. But the quality is good other than fitment. Nice carbon.
Quote from: DarkStaR on January 03, 2009, 10:21:59 AM
I'd say bad part.
DarkStaR
January 03, 2009, 10:27:20 AM »
Quote from: JTMOTO on January 03, 2009, 10:25:02 AM
Hey, even DP carbon is crap 50% of the time. If you have faith in them, you could try another one...but I wouldn't.
geoffduc
18 till i die
January 03, 2009, 10:34:02 AM »
JT i've fitted a couple of the replacement carbon fiber front mud guards on that model with on problem so check the width of your tyre and if thats the normal fitment size i should return the mud guard to the vendor for replacement.
It looks on the photo that the moulding is out of shape.
2015 scrambler FT
2009 monster 1100s
January 03, 2009, 10:41:07 AM »
Is it that close/rubbing on both sides?
You could try adjusting the position with the bolts just a little more than finger tight, then carefully tightening the bolts to maintain the correct position....if you've got room on the other side.
Otherwise, exchange for another.
Capo
You Are What You Is
January 03, 2009, 11:01:55 AM »
The wheel rotates into that edge, if it were to catch and dig in the result could be dangerous. I'd want much more clearance.
Capo de tuti capi
