Last question (Rizoma Rearset install related)
Started by JTMOTO, January 03, 2009, 10:05:12 AM
JTMOTO
http://i455.photobucket.com/albums/qq277/jtmoto/jtmoto0037.jpg?t=1231005295
Has anyone installed these or any others and felt like this bolt could just fall off at any moment.  I tightened the heck out of it at first only to realize that it wouldn't allow the transmission to shift and then I loosened it and it gives me an uneasy feeling like it could fall off at any moment.  MAYBE i AM JUST PARANOID ???
DucLeone
DUCATI NON E UNA MOTO, E UN STILE DI VIVERE
KISS FRENCH AND RIDE ITALIAN
S2R 800 Black
Statler
Can't tell from the size of the pic...is that a nylock nut?
JTMOTO
#3
Yes
Quote from: Statler on January 03, 2009, 10:16:05 AM
DarkStaR
I tightened the sh!t out of mike on the stockers, but my joint is on the other side of the shifter arm.
Does Rizoma instruct you to install the joint on that side of the shifter arm?
JTMOTO
Not sure, there were no instructions with them.  Do you think it should go on the other side?
Quote from: DarkStaR on January 03, 2009, 10:50:14 AM
DarkStaR
Quote from: JTMOTO on January 03, 2009, 11:39:45 AM
I think you have it on wrong!
Check this out:  http://ducatimonsterforum.org/index.php?topic=15645.msg296771#msg296771
I don't understand how changing the direction of the bolt will fix the too tight/too lose problem - the angle is causing the issues?
You don't have (or use) the black Rizoma rod. Are they, or rather their end pieces, different? Could those differences cause these issues?
(just thinking out loud)
DarkStaR
Quote from: stopintime on January 03, 2009, 12:58:30 PM
The heim joint is on the wrong side.
JTMOTO
That is what was in the rizoma box.  No black rod.
corey
yea, if i'm not mistaken, those rizoma rearsets shouldve come with a new shift linkage rod. check under the bubble wrap in the bottom of the box...
lazarus7
Quote from: corey on January 03, 2009, 04:33:55 PM
speaking from experience...... [bang] [bang] [bang] [bang] [bang] [laugh]
youll find a new longer linkage rod in the bottom of the rizoma box.... ;)
just thread it into the stock heim joints, dont move them, just thread the linkage rod to the correct length....
"...the greatest artists indulge in a 'culpable rivalry' with God."     Stanislas Fumet
JTMOTO
Quote from: lazarus7 on January 03, 2009, 05:42:19 PM
That is the longer supplied rod.  It is just not black.  I switched the side and I was able to tighten the heck out of it and it shifts fine.  Thanks!!!....that could have been really bad if it came off mid journey.  Once again, glad I asked
JT
OwnyTony
Did you figure it out?
I have the same rear sets.  I have mine higher which means to get them to work, you have to shift in reverse/gp style. Basically pushing down on the shift is going up a gear and down shifting is raising the shift up.  Better pics bellow.  Also, there was a longer linkage rod and you put it on the inside.  It uses a nylock nut if I remember correctly and a dab of threadlock is always good.
http://ducatimonsterforum.org/index.php?topic=6704.msg138283#msg138283
