Newer fender on older bike?
Started by greenmonster, January 08, 2009, 05:19:39 PM
greenmonster
Has anyone fitted a -00 or newer front fender to a 90`s Monster?
Possible?
How to make brackets, guess you need such?
Looks OK, anyone got pics?
Maybe stupid question, someone ought to have done it already if possible but I got a sweet deal on a carbon one going....
M900 -97
MTS 1100s  -07
JEFF_H
The older bike has 40mm spacing bolted directly to the fork, the newer one has 65mm spacing using a strap that goes around the forks
maybe you could make some sort of bracket to adapt one to the other...but i dont think it is going to be simple.
better to get the one made for your bike (although the older ones are getting hard to find)
teddy037.2
+1
you're gonna be looking at fab work. oooorrrr.... change your forks to the ones w/the newer spacing!  [evil]
Why not use the factory lower mounting point and modify a couple of the plastic bands to work on the top?
greenmonster
40/65mm spacing I`m aware of.
But,
got the seller to measure leg to leg, seems my fork legs are about 20mm wider apart.
Could this really be true, were there new yokes from -00?
M900 -97
MTS 1100s  -07
