January 09, 2025, 11:48:14 AM
Looking for S4RS dyno results...
Topic: Looking for S4RS dyno results... (Read 1621 times)
TAftonomos
is without a monster :(
January 08, 2009, 09:01:20 PM »
Just as the title says, only I'm looking for dyno results comparing an ex-box exhaust with a full termi or arrow. I believe the full termi or arrow makes more power, but I'd like to know how much more before I go about designing an exhaust system for my bike. Biggest thing I can see is the exbox or underengine exhaust has no room for a proper merge collector...which is important for power production.
Can't quite decide if loosing 10lbs is worth the power loss of the underengine exhaust (the loss I'd suspect).
The proper way to do it (IMHO) is the termi, but I can't stand the shotgun look, and I'd like to be "different".
I also don't want quite as much noise as my megs in the video....
MyDucParts.com
hypurone
Re: Looking for S4RS dyno results...
January 09, 2009, 06:51:27 AM »
Hey man, I looked and can't find my actual printout but:
An 07 w/ 50mm full Termi system and a PCIII (cuz I had to have it running just so) on an actual factory Dynojet dyno (at an approved dynojet tuner) yielded 139.8 RWHP and 81.1 Ft LBS on a 70 degree day. It is quite possible that I lost a couple of HP by running a fairly fat A/F ratio (13:1). But I wanted it for reliability and cooler running.
I bring up the dyno mfg and location as you are gonna some some wild numbers depending on the type of dyno and the correction factor used. I figured an actual Dynojet dyno from a certified tuning station would give you a solid number as a reference point.
TAftonomos
January 09, 2009, 10:18:44 AM »
I'm actually hoping to find someone who had the ex box and then got the termi's, AND had it dyno'd at the same place. Or at least a dyno facility that has done either exhaust on different bikes would be a good start.
Comparing bike A to bike B at different dyno's, is pretty much worthless (unfortunately).
MyDucParts.com
Icon
January 09, 2009, 11:04:22 AM »
Your not going to see much of a gain of any from the E-box. I was looking into this about 6 months again and I called up Motowheels and asked them about this and they said the E-box was just for looks. I already knew this, but wanted to hear from them.
Ducnial
January 09, 2009, 08:13:22 PM »
'07 S4R w/DP ecu and Termi Slip-ons
http://i44.photobucket.com/albums/f26/ducnial/my_dyno.jpg
Last Edit: January 09, 2009, 08:22:32 PM by Ducnial
DesmonsterS4RS
"The Desmodromic Symphony"
January 12, 2009, 06:03:23 PM »
I have full Arrows, open airbox, K&N, and a DP ECU, my bike put down 132 RWHP, and 74 LBFT. Should be a little higher once I get a PCIII
07 S4RS, Full Arrows (CF), DP ECU, Open Airbox, K&N, Speedymoto Gold "Kukri" PP, Rizoma Clutch Cover, DP Gel Seat, Cookies1 Tail Chop, 14 Tooth Front Sprocket, CRG LS, Dyno Tuned by AMS 132rwhp, 74 lb ft.
