January 09, 2025, 11:44:53 AM *
Author Topic: Emissions Removal Kit...  (Read 4136 times)
AZMonsterMan
« on: January 14, 2009, 08:18:01 AM »
Has anyone installed the Emissions Removal Kit from TPO Parts on their Monster?
I have a '01 M750 think I may have an emission system leak and instead of taking all the time and grief to locate the leak I am considering the removal kit.
The problem is that I live in AZ where we have to get emissions done. Will this kit make it unable to pass emissions or does this kit just remove the stuff necessary to make it pass is CA?
Thanks!!!
 chug
"It was on the tip of everyone's tongue, we just gave it a name."
                                -Fight Club
Omnipotent Potentate
Personal Pretext
« Reply #1 on: January 14, 2009, 08:23:42 AM »
That kit is just a can of carbon that catches over flow gas from the tank breather system - it's not related to tail pipe emissions.
rule62
« Reply #2 on: January 14, 2009, 08:27:53 AM »
Hey MonsterMan,
There's enought people here in Phoenix that'll help you remove all that emissions stuff without needing the TPO kit.  Save your money.  Your bike, if it's running properly, will pass the Phoenix, AZ emissions test with the evap canister removed.  PM Dietrich to see when he's up for another "garage day".  I was hanging with him and the previous owner of your bike (DucDucDave) last night at the TT Roadhouse on Thomas and 68th, and we were talking about how cool it would be to have that bike "back in the family".
corey
'06 Tang/Black S2R800
« Reply #3 on: January 14, 2009, 12:39:50 PM »
Yes. I have installed the TPO kit. It's just some hose, some zipties, and some screws to plug the holes in your air intakes.
It works. Has everything you need. And it's cheap...
You can do it without it for sure, just need to find the right intake plugs.
rule62
« Reply #4 on: January 14, 2009, 01:55:24 PM »
M5 bolts from hardware store $0.15 each.
corey
« Reply #5 on: January 14, 2009, 02:24:16 PM »
not sure bout your bike, but my intake holes were much much smaller than an m5 bolt.
Holden
Sausage Creature
« Reply #6 on: January 14, 2009, 02:28:11 PM »
Just get some rubber vacuum caps to fit over the nipples that the hoses were attached to.
« Reply #7 on: January 14, 2009, 02:28:50 PM »
696 is not M5. i didn't verify which though, just used a vacuum plug.
rule62
« Reply #8 on: January 14, 2009, 09:23:03 PM »
2004 620 = M5 (metric size 5) bolts.  They don't plug the teeny tiny holes, they replace the "throttle-body tits" entirely.
Vacuum caps work great too.  Just give 'em a check now and then to make sure they're still there.
You can also just run some of the stock tubing from one "throttle-body tit" to the other.
« Last Edit: January 14, 2009, 11:10:49 PM by rule62 » Logged
corey
« Reply #9 on: January 15, 2009, 06:40:25 AM »
yea, i removed the nipple entirely as well... i'll have to check and see what size they were, i guess they couldve been M5. I remember the kit came with 2 sets of bolts to use as plugs, and I used the smaller set...
« Reply #10 on: January 15, 2009, 07:37:32 AM »
just make certain that you seal those bolts REALLY good. a vacuum leak will make it run like crap
CDawg
S4RS
« Reply #11 on: January 15, 2009, 07:07:16 PM »
bought it, installed it, love it!
sure you pay a premium, but it's darn hard to find some of the parts in NYC.
ejw24
'06 M620 - The Radical Red Racer #2
« Reply #12 on: January 16, 2009, 09:27:39 PM »
+1  I live in Aspen and you can't find ANY parts/pieces here
I'm having a failure to thrive...
zLoki
Why yes, it is dangerous
« Reply #13 on: January 18, 2009, 02:17:17 AM »
I've run mine for a few days without sealing the intakes,  no noticeable difference in performance.  Am I missing something?  Perhaps long term damage?
Mostly stock '12 796
Sold - '09 696 with 30,000 miles
« Reply #14 on: January 18, 2009, 11:45:58 AM »
well essentially you would be running too lean (a mechanic chiming in here would be appropriate) since you would be sucking in air after the sensors.
