2001 monster 900 ecu pinout diagram needed
Started by duker, January 15, 2009, 02:25:15 PM
duker
I have a pc3 that had the connectors destroyed where it plugs into the ecu and need the wiring diagram to wire it in myself.   Power commander gave me the color codes but dont have the info on which wires go to what. Is there a service manual with the pinouts on it? All I found so far is the chassis wiring diagram.
Quote from: duker on January 15, 2009, 02:25:15 PM
There is another diagram in the shop manual for the ecu
You might pm ducvet...
duker
The manual i have must be for the carbed version . It doesnt show a efi system on either diagram. Can anybody post up the correct diagram. Thanks
2001cromo
the 2001 manual doesn't show the pin outs for the ECU. It just shows the wiring schematics
Maybe ask Duane at FIM for this info?
duker
Could someone who at least has the correct diagram post up the wiring schamatics .I would apreciate it.
