Cam Seal Replacement '95m900 (formerly: Oil Leak from behind belts?)
Started by erkishhorde, January 15, 2009, 06:39:35 PM
erkishhorde
So in addition to my little fuel problem...  :(
I popped off the belt covers because I thought I was hearing a scraping noise from the right  hand side of the bike. I found nothing scraping but I did find this.
The rubber thingy that has the threads for the belt cover has a crack at one of the screws and there was a dribble of oil coming from there. Odd thing though, after a 55 mi jaunt of the freeway I got home and there was no oil dribble anymore. I guess it could matter that before I saw the oil I had burning down the fwy at 85-90mph for 55mi and when I checked on it again and saw no oil dribble I had only been going about 70-75mph.
So, is this thing hard to replace? I have no idea how to take that pulley off. I haven't looked in my Haynes manual yet. Thoughts?
corey
i'm no expert. but i think that blows.
erkishhorde
Bugger... Should be OK to run on for a little bit so I can make my trip, right?
Quote from: erkishhorde on January 16, 2009, 07:06:13 AM
If it's minor it wouldn't stop me.
I rode my 750 track bike with a leaking lay shaft seal for a season.
scott_araujo
I don't think it's too big of a deal to replace your cam seal.  One thing though, that large nut that holds the pulley on is a one use item so you'll need a new one along with the seal.
Scott
erkishhorde
Quote from: scott_araujo on January 16, 2009, 08:27:49 AM
Scott
Really? That sucks... What about it makes it a 1 time deal?
I'm finally getting around to doing this repair. It's getting oil all over the side of my bike.  >:( So I've figured out a way around the Ducati specialty tool. I should have looked in my Haynes manual from the start.  [roll] Anyway, think I'll be needing anything other than just the cam seal? Scott mentioned a new pulley nut. Think I'll really need it? I'm trying to start a parts list now so I'll be ready when DucSea is open tomorrow and maybe I'll get my bits by this weekend if they're in stock.
Quote from: erkishhorde on April 06, 2009, 02:47:00 PM
Do you really need to replace it?  Maybe not , but it is self locking, designed for one time use.  Do you want to take the chance?  I wouldn't  If the nut comes off so does your belt.
erkishhorde
#8
Quote from: howie on April 06, 2009, 03:00:29 PM
Ah, that's the part I wanted to hear. I don't particularly have any problem with getting extra bits that people suggest I might need but I like to know why. Plus I think I'm gonna be doing this work at my parent's place and my dad always asks me why I need stuff and "because so and so told me I do" isn't the greatest answer. Thanks!
Oh also, judging from the amount of oil all over the place I'm assuming that the belt has be thoroughly covered in oil. I haven't opened it again since to look but that's my guess from all the oil I see seeping through the covers all over the place. Should I replace the belt as well?
Quote from: erkishhorde on April 06, 2009, 05:15:39 PM
I would, some rubbers don't like oils.
I'd agree, if the belts are oily, replace 'em.
And those belts are relatively cheap.
Take care to get the replacement seal installed flat.
