January 09, 2025, 11:50:42 AM *
Author Topic: pick up points for DSS  (Read 1185 times)
The Don
« on: January 16, 2009, 03:19:56 PM »
Hello there
Has anyone fitted pick up lugs for their DSS. I have just bought some and there seams to be no factory thread for me to fit the lugs to. Can you tell me can or should I fit them and where should they go.
Thanks in advance
Don
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
JEFF_H
« Reply #1 on: January 16, 2009, 03:21:48 PM »
you mean spools?
Pit bull makes some inserts you can drill and insert in the swingarm
The Don
« Reply #2 on: January 16, 2009, 03:25:45 PM »
Boy you blokes are quick
that would be them, the packet i have calls them frame bobbins, the are for a track stand.
The Don
« Reply #3 on: January 16, 2009, 03:30:17 PM »
Is there a certan place they should be located, for structural integrity.
Capo
You Are What You Is
« Reply #4 on: January 16, 2009, 03:33:23 PM »
Looks like a nutsert to me
Capo de tuti capi
« Reply #5 on: January 16, 2009, 03:49:50 PM »
About on centerline, far enough forward of the axle that your stand doesn't interfere with the axle/nut.
Try to drill a good, smooth hole, no raggedy edges to start a crack.
Drill small, and use a tapered hand reamer to get it just big enough to slip the rivnut into.
JEFF_H
« Reply #6 on: January 16, 2009, 03:50:13 PM »
This is the other part (the bobbin if you will)
i dont think it is critical where you put it...near the rear axle where you have room for it (and not blocking access to the axle nuts.
FYI- I was taking with pitbull about these and they said if you want to ship them your swingarm, they will weld the spools on for no charge...
just a thought.
The Don
« Reply #7 on: January 16, 2009, 06:10:36 PM »
just a thought.
Thanks for the offer but probably a little too far considering I'm in Sydney. Thanks for everyones input, much appreciated
Regards
Don
