How to core 696 pipes (thanks to ryanracer)
Started by mitt, January 20, 2009, 07:49:05 PM
How to core your pipes on a Ducati Monster 696
Step 1
Step 2
Step3
[u
Step 4
Step 5
Copied and pasted from this thread
http://ducatimonsterforum.org/index.php?topic=17976.msg0#new
Here is the sound comparison of STOCK vs. CORED
WetDuc
As a quick addition to this great tutorial, I wanted to point out that there is an alternative way of getting the sleeve off the left can.
I used a steel tube about 5 ft long, just smaller in diameter than the inlet of the can and then immobilized the can (bench vise, under something heavy, etc) and gently used the steel tube as a lever to bend the inlet pipe more straightened until the sleeve could clear and slide off.  The same method was used to re-bend the inlet pipe once the core/chop was done and the sleeve was back on.
No cutting, took 30 seconds and worked great.
Goju
Hi, I have a spare set of 696 cans I would like to core, does anyone still have the pictures for this process, they are not showing in this thread, cheers David
