Monster 900 year97
Started by speedpostz, January 23, 2009, 09:28:51 AM
speedpostz
Hi guys, i have a gt1000 wired rims and i wanna fit onto my bike.
any one done this before? I brought it to my mechanic but he said it cant be fitted
as there is some clearance for the brake caliper. i was told be him that the wheels can be fitted
nicely but the brake caliper cannot be fitted in as it is hitting the wire spokes of the rim.
the suspension and the brake caliper are stock from 97 m900. help would be greatly appreciated,
picture would be great too. thanks everyone
JEFF_H
im pretty sure the sportclassics use the smaller 2-piston calipers.
you would prob have to switch to those...
paging duck-stew.
stew to the mods section please
speedpostz
the main thing is there is not enough clearance for the caliper to befitted in as it is blocked by the wired spoke. thinking of grinding the back of the brake caliper but my mechanic says its not advisable as there is a risk that the caliper cannot be used.
Your mechanic is correct.  The fitment of the caliper over the rotor can't be done on the SC wheels with any of the Brembo stock 4-piston calipers.
What you need to have done (think $$$ here) is to have rotor spacers machined (5mm ought to do it but PLEASE check first!) so the rotors sit out further from the spokes.  Then have custom caliper spacers machined to the same offset dimension as your rotor spacers.  After that, it's a matter of bearing spacers front and rear and you'll have no provision for the mechanical speedometer drive in the left side of the front wheel so you'll need to work around that issue also.
Best of luck!  [thumbsup]
speedpostz
oh ya.. my mechanic told me that the speedometer cannot be used and suggest that i can use those on a bicycle eg cheap looking digital type used on the bicycle for my bike if the wheels can be fitted. is it possible to post a close up of the wheel showin the brake caliper plus the rotor? then im able to show the mechanic what you meant as he is not english speaking, and i can better illustrate to him, showing him the pic.
PLEEASZE?
