January 09, 2025, 07:51:54 PM *
Author Topic: Oberon Mirror  (Read 1718 times)
flanman
« on: January 23, 2009, 01:38:53 PM »
Well I ordered the "streetfighter" bar end mirror from them. It took about 2 and a half weeks to get here (but that time frame was over the holidays/new years). I had no trouble dealing with them Smiley I measured the internal diameter of the stock bars and ordered the according size but for some reason the mirror I ended up getting didn't slide inside... The small lip that appears to be meant to sit inside the bar just was too big and I had no real way of shaving it down. So I ended up making a rubber washer that fit the gap (the end on the bar is somewhat tapered in and the mirror rests flat against it so there is about a .25 inch space). With the new spacer it fits on there nicely. Easy install the brass collet expands to really hold it in and the mirror has many different positions to play around with. It is small but works well (in my opinion). Very little vibration the only real difficult part for me at least is getting used to the lower location. From the stock taller bars it is way different to check (not a bad thing just takes time getting used to). It is still winter here in New England so a quick ride today and yesterday really hasn't allowed me to get it set perfectly where I want it but so far so good.
What it came with minus the black spacer/washer
You can see where I put the spacer in
ruester007
on the 8th day he chopped the tail and went riddn
« Reply #1 on: January 23, 2009, 03:54:38 PM »
They seem to be pretty nice. I think I like them more than the crg's. Just my 2cents
2007 - S4RS - Full termi system, integrated front signals/mirrors, Cox Racing radiator/oil cooler guard, frame sliders, DP tank guard, tinted windscreen, Sergeant Seat, pressure plate, spring retention caps, RCM clutch cover (painted), tail chop, emission removed, reflector removal
IN PROCESS - Rizoma clip-ons, grips and ends, Sodium blasted wheels
scoprire
« Reply #2 on: January 23, 2009, 05:26:12 PM »
I've had mine for over a year now.  They are a pain in the a$$ to get set the 1st time, but after that they stay where you set them.  They are really well made, and worth the trouble.  If I didn't already have them, I might try their version that has a bit larger glass, but you'll get used to them quickly.
Oh and don't bump into them in the garage.. they don't move out of the way like most mirrors. Smiley
geoffduc
18 till i die
« Reply #3 on: January 24, 2009, 04:30:26 AM »
Mr Flanman i'm glad yu are happy with the oberon mirror that you have fitted. I helped a mate fit a pair last year and he swears by them but i could not get used to the position and thats one of the reasons i installed the normal type of mirror on my HM  [moto]
2015 scrambler FT
2009 monster 1100s
