January 10, 2025, 01:23:21 AM
Rizoma bar end problems.....HELP
Topic: Rizoma bar end problems.....HELP (Read 2431 times)
muskrat
January 24, 2009, 10:23:07 PM »
I bought these
http://www.desmoworks.com/index.php?main_page=product_info&cPath=6_383&products_id=395
and received them. They look great but there is no way to mount them on my Ducati S2R handlebar. I then bought
http://www.desmoworks.com/index.php?main_page=product_info&cPath=6_383&products_id=392
and the problem is that the diameter of the mirrors is too large to fit on the bar end sliders shown in the second picture. The two inserts, one plastic and the other rubber (2 of them) are incompatible and allow the mirrors to spin freely. Can you tell me what bar ends I need so as not to move my controls all the way in and do such large modification? Here is a pic of the correct setup
http://www.pjsparts.com/catalog/product_info.php?products_id=36
Thank you for your help guys
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
DarkStaR
Re: Rizoma bar end problems.....HELP
January 24, 2009, 11:19:00 PM »
So what doesn't fit:
1) the Bar ends in the bars?
2) the mirrors on the barends?
3) All of the above?
I've run in to the same issue, but I need clarification before i can give you good answer.
Also, did your bike come with the (metal) barends?
Last Edit: January 24, 2009, 11:20:59 PM by DarkStaR
be350ka
January 25, 2009, 07:46:13 AM »
I have the same setup and there are "0" directions from Rizoma, but you can find your way through. What you need to do is find the correct expansion plug that is included with the barends. Fit it to the bolt and when you place it into the bar and tighten the bolt down it will expand keeping it from spinning freely. I think I used the largest bar "plug" when I fit mine.
As far as the mirrors go there are some plastic sleeves that come with the bars to allow them to fit tighter. I used the "white" one and they fit fine.
mrplease
January 25, 2009, 08:43:28 AM »
i don't know what to tell you because i have the same exact set up on mine and it fits perfect!
www.cardomain.com/id/mrplease
TrpprJhn
February 28, 2009, 08:05:09 AM »
I like your set up with those Rizomas, I have the exact same bike. Did you install them yourself? Any tips?
Munch
Monster S4R - Munchstrada 1100S - 749R
February 28, 2009, 07:16:39 PM »
Flip the mirrors over... Looks better!
Holden
Sausage Creature
February 28, 2009, 07:19:29 PM »
Quote from: Munch on February 28, 2009, 07:16:39 PM
Loses a lot of the max steering lock.
patorojo
February 28, 2009, 07:53:41 PM »
Quote
Having just installed a set of Rizoma bar end mirrors and bar ends, I echo the comment above that there are no instructions. I did find that the appropriate bushing for the mirrors was a snug fit on the bars that required a rubber hammer to get everything in place prior to tightening.
Arne Berger
2007 S2R1K
2007 DL650
2005 DRZ400S
Munch
February 28, 2009, 08:31:03 PM »
Quote from: wark on February 28, 2009, 07:19:29 PM
I get full turn without touching the tank.
Holden
Sausage Creature
February 28, 2009, 09:14:21 PM »
Quote from: Munch on February 28, 2009, 08:31:03 PM
I thought you were referring to mrplease's 696, not the OP.
Last Edit: February 28, 2009, 09:16:52 PM by wark
March 01, 2009, 12:33:57 AM »
Quote from: patorojo on February 28, 2009, 07:53:41 PM
i'm having the smae problem with my mirrors and bar ends. trying to find a solution. but everytime i crank the mirrors down to tighten them and it doesn't work i can't get them to open back up enough to stick a new bushing.
teddy037.2
March 01, 2009, 09:27:00 AM »
I have the same setup (barends and mirrors), and had no fitment issues. the thinnest white sleeve was the one that I used to fit the mirrors, and they're pretty dang solid.
