Installing new horn
Started by LMT, May 05, 2008, 04:33:54 PM
How hard is it to install a new horn?  I got a Fiamm freeway blaster in low tone, and a relay.  The package says "easy to install".
I can fill the gas tank, lift the tank, charge the battery or put in a new one, check the tire pressure, and oil the chain.  This is the extent of my mechanial ablity.
Where is  the spell check?
Quote from: czaja on May 05, 2008, 04:33:54 PM
We need pics of what you bought so we know where it will fit.
That will fit where the original is located.
Did they give you a mounting bracket?
Ddan
The relay would probably be nice, but I doubt you need it unless you really like to lean on the horn button.  Plug it in and scare some cagers.
Ducati Monster Forum at
www.ducatimonsterforum.org
I will be riding to work on Seattle freeways.  I need the horn to wake up the cagers.
hypurone
I replaced my stocker with a matched hi/lo pair. Hella loud.  A little too loud when just trying to give a beep to say thanks for pulling over to let me pass.  ;D
But to answer your question, it won't be hard at all. Just mount the thing in place of the stock and connect the wire(s). I doubt you will really need a relay unless that sucker draws some serious power.
Thanks for the info!  I think I can do this   be::
hypurone
CDawg
Check the amp draw for the horn.  If it is below 6amps (I believe) you won't need a relay, if it is above, then you do.  If you need a relay, but didn't install it, then one of 2 thing can happen: (1) horn is not too loud or (2) you'll fry the fuse.
I got a relay and will look at the OM horn wiring diagram.  I read the instructions on the new horn and it seems doable.
Only one horn?  No need for a relay.  You may have to change connectors and modify the bracket.
Kurt
Quote from: hypurone on May 06, 2008, 05:11:01 PM
Maybe you (and anybody else!) can help me out?
I am installing Hella Twin Supertone horns (and supplied relay) on my '07 S4R.  These are them:
http://www.autobarn.net/twinsuphorki.html
Did you tap into the stock wiring or make up a new sub-harness?
The wiring diagram in the handbook is microscopic, for one thing.  Do you know whether the stock horn push carries current, or makes the ground?
I am thinking of going with making up a separate sub-harness and using a separate horn push and staying away from the original wiring harness altogether.
Any ideas and suggestions welcomed.
Thanks,
-Kurt
PS -- I installed a pair of these on my '69 Triumph 650 -- they are loud!  In that case, I used the original horn push which completes the ground, and I made up the rest of the harness separate from the original.  The bike of course is a lot simpler to work on, just have to remember that the electrical system is positive earth/ground.  ;D
hypurone
Quote from: Kurt on August 12, 2008, 10:23:07 AM
Thanks,
-Kurt
I kept the original wiring in place and made a "piggy-back" harness to run the second horn. I simply used some equivalent gauge wire (12ga I think it was) and some of the dual spade connectors that turn a single spade attachment point into two and wired it up. 7000 miles later,  a liberal amount of use  [evil] and still working like a champ.
NOTE: A word of caution if you ride in the rain, you may want to take extra care in pointing the horns away from the spray of the front wheel...
