January 24, 2025, 08:51:30 PM
Airbox Mod Help
Topic: Airbox Mod Help (Read 2783 times)
Bellagio
Leo Vince pipes give me a
Live Fast, Die Young, Leave a Beautiful Corpse
Airbox Mod Help
January 27, 2009, 06:19:04 PM »
I'm kind of nervous to cut up my airbox on my 02 620. The top looks like there is a lot of molding and I'm just curious as to how much plastic I should cut out. Plan on doing a K&N filter filter as well if that means anything. If anyone could post pics of their modded airbox it would be greatly appreciated! Cheers!
May your head gasket develop premature failure, your carb get gummed up, and your side stand fall short.
rkundrat
Re: Airbox Mod Help
January 28, 2009, 05:43:24 AM »
I'm also interested in this and have heard of partially opening (like just removing the snorkel) and fully opening (like the DP airbox top.) Are the sound and airflow gains comparable? Got a spare ready and waiting to go under the knife!
Italians have it pretty figured out...
2003 Monster 800s i.e.
Remus high-mounts • PCIII • Evoluzione slave cylinder • Tommaselli clip-ons • CRG & Pazzo levers • Sargent seat • CRG bar end mirrors
1992 Alfa Romeo 164S
mookieo2
Re: Airbox Mod Help
January 28, 2009, 05:47:05 AM »
I`ll try to get a pic today. My gas tank is off so it is a good time to take a pic for you. Basically just cut the whole top off and leave the sides of the top cover.It sounds great when you open up the throttle. Like it is going to suck you in.
Chchadder
Re: Airbox Mod Help
January 28, 2009, 05:49:34 AM »
It's pretty much up to you how open you want it. The thing I didn't like about having an almost completely open airbox was that the intake sound was directed right up into my face. Also keep in mind that this mod will lean out the A/F mixture a bit, and without the DP ECU there is not much wiggle room to richen it up. I ended up going with pod filters after having it open for a while, but that mod opens up a whole other can of worms.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
rkundrat
Re: Airbox Mod Help
January 28, 2009, 06:00:23 AM »
Quote from: Chchadder on January 28, 2009, 05:49:34 AM
So Does a partially-open lid give you the flow increase without the sound coming straight up?
Found this shot of the DP lid (fully open.)
I have an exhaust and pcIII, so the bottleneck right now is the airbox.
Oldfisti
My mom says I'm a catch.
Re: Airbox Mod Help
January 28, 2009, 06:45:47 AM »
Quote from: rkundrat on January 28, 2009, 06:00:23 AM
You will definitely hear intake noise especially in the upper rpm range. I personally like all the mechanical sounds my bike makes. My clutch is open too.
P.S. I have 2 Alfa 164's
mookieo2
Re: Airbox Mod Help
January 28, 2009, 07:06:43 AM »
Mine looks like the pic. I had it done when I got it serviced and it was re dyno`d. It was running lean to begin with. I love it.
Chchadder
Re: Airbox Mod Help
January 28, 2009, 08:12:38 AM »
yeah, lots of people love the open airbox sound. I love my bike loud too, don't get me wrong. It was just a bit too in-your-face for me.
toaster
Re: Airbox Mod Help
January 28, 2009, 09:08:03 AM »
Quote from: Chchadder on January 28, 2009, 08:12:38 AM
if you think its loud with the open airbox, dont do pods. the cut box is nothing compared to doing pod filters. im running pods and my exhaust is just the headers and going down the highway at 80 i can hear the intake over the exhaust.
Chchadder
Re: Airbox Mod Help
January 28, 2009, 09:34:24 AM »
Pods are definitely louder, but more balanced IMHO. Much more of a snarl than an open roar, and not going right back up into your face. Problem with pods is that you lose the crankcase recapture to the vent tank and airbox. Not that big of a deal unless you like to do long high wheelies, in which case the filter you now need can spill oil out the back and possibly onto your rear tire...
JEFF_H
Re: Airbox Mod Help
January 28, 2009, 11:19:24 AM »
also- be aware that opening up the intake will almost certainly require jetting/tuning changes to compensate for the extra air...
Oldfisti
Re: Airbox Mod Help
January 28, 2009, 02:54:10 PM »
Quote from: JEFF_H on January 28, 2009, 11:19:24 AM
+11tyb
Bellagio
Re: Airbox Mod Help
January 28, 2009, 06:46:47 PM »
Thanks for all the input. I'm going to put in the K&N filter and ride around on it like that for a while. I'll cut up the box mid season. Cheers!
eichh
Re: Airbox Mod Help
January 29, 2009, 03:36:49 AM »
Heres mine.
toaster
Re: Airbox Mod Help
Reply #14 on:
January 29, 2009, 10:12:31 AM »
Quote from: Chchadder on January 28, 2009, 09:34:24 AM
i did mine different than most people for that though. i took the hose where it went into the stock airbox and put a small filter right up there on the end of it. the hoses run into the same exact place they used to but now it ends with the filter.
