January 09, 2025, 07:46:03 PM
Please Help
Slave Cylinder
Topic: Slave Cylinder (Read 1280 times)
JTMOTO
Slave Cylinder
January 31, 2009, 08:51:52 AM »
Does anyone know what would be the ideal size in mm for an aftermarket slave cylinder for the wet clutch S2r 800?
I thought you could just buy any of them, and now I am seeing 30mm,28mm and so on.
mmakay
695
Re: Slave Cylinder
January 31, 2009, 09:54:09 AM »
What is your goal? Bling? Improved feel? Lighter pull?
The smallest available will work most like stock, and should be fine for a wet clutch. The larger the piston, the longer the friction zone, and lighter the pull. Those are best for dry lutches.
- Mickey
JTMOTO
Re: Slave Cylinder
January 31, 2009, 11:10:15 AM »
feel and bling.quote author=mmakay link=topic=18565.msg331222#msg331222 date=1233424449]
[/quote]
Last Edit: January 31, 2009, 11:12:17 AM by JTMOTO
cloud2blue
2000 m750, 2001 m900ie, 1999 ST4, 2005 999s
Re: Slave Cylinder
January 31, 2009, 12:18:57 PM »
Someone correct me if I'm wrong, but it was my understanding that a slave cylinder made to fit a Ducati will fit every model and the "size" was more about how it works, than what models it fits. And isn't it the larger the bore, the lighter the pull? Or something like that.
Pictures
Online
Re: Slave Cylinder
February 01, 2009, 04:52:13 AM »
Quote from: cloud2blue on January 31, 2009, 12:18:57 PM
In '01 there was a change in the OEM slave and push rod. Aftermarket companies have their own way of dealing with this. Safe bet is buy through one of our sponsors. They know proper fitment.
moto
Re: Slave Cylinder
February 01, 2009, 07:33:40 PM »
We recently installed a
STM
on the M696 (wet clutch) and it did not make much difference at all on the clutch pull. I'm not sure if any of the larger slave cylinders will reduce the lever effort by much on the wet clutches. It probably will reduce the leak issues though.
On our 1098 project, the 30mm
STM
reduced the lever pull effort by about 30%. We then swapped out the 30mm STM with a 29mm
Oberon slave cylinder
on our 1098. The clutch pull was about the same as the STM--but finding neutral was easier with the Oberon.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
mxwinky
'08 S4RS Tricolore #187, '95 900SS SP, MTS 1000S
Re: Slave Cylinder
February 02, 2009, 09:58:09 AM »
The larger bore will equate to easier pull at the lever. If that's your main goal, go with the 30mm. Since the 696 already has a one-finger clutch pull, you're not likely to notice much difference on that bike when you change the slave, though the billet aftermarket piece will last longer and look nicer. On your S2R 800, if lightening the clutch pull effort is your main goal, go for the 30mm unit.
vwboomer
Re: Slave Cylinder
February 02, 2009, 09:56:45 PM »
FWIW I just ordered from Oberon this weekend - $121 shipped. For that price I couldn't say no!
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
JTMOTO
Re: Slave Cylinder
February 03, 2009, 04:55:08 PM »
Quote from: vwboomer on February 02, 2009, 09:56:45 PM
Where did you get this price?
vwboomer
Re: Slave Cylinder
February 03, 2009, 09:35:20 PM »
umm. From....Ob....eron.
http://www.oberon-performance.co.uk/acatalog/ducatiSpecials.html
For some reason the paypal charge showed up as 121 instead of the 115 that Oberon's currency converter said. But still a good deal.
2005 GasGas FSE450
2004 Honda VFR
