![](http://ducatimonsterforum.org/Themes/default/images/post/xx.gif) |
« Reply #60 on: March 12, 2009, 12:16:27 PM » |
............................... also hoping to remove one of the two spacers on either side, still kindof a reach to the levers even adjusted all the way towards the bar.
I swapped right/left riser parts and rotated them. The result was almost no spacer requirement, but only almost - so one is on. You'll need 30mm bolts instead of the 25mm you have now (riser to fork clip connection) You'll also need to raise the clip ons a little for them to clear the fork tops. will the ceramic coating protect my leg against heat? i wrapped it because i ground off the mounts for that awful guard thing. why does ducati put so many weird triangles in the new design. i'm against triangles. we need more squares and circles. jmho.
I've seen melted boot marks on wrap, so I think they get hot enough.
Holden
« Reply #61 on: March 12, 2009, 12:29:53 PM » |
I agree (I just took the heat shields off and left the mounts—still looks better). But has your leg ever touched there? I would have to go out of my way to do that, and I think I wouldn't be touching it long enough to feel any heat through my pants if I did. P.S. Clip-ons look much better now. ![waytogo](http://ducatimonsterforum.org/Smileys/classic/waytogo.gif)
OstOgBajer
« Reply #62 on: March 12, 2009, 02:44:14 PM » |
I agree (I just took the heat shields off and left the mounts—still looks better). But has your leg ever touched there? I would have to go out of my way to do that, and I think I wouldn't be touching it long enough to feel any heat through my pants if I did. P.S. Clip-ons look much better now. ![waytogo](http://ducatimonsterforum.org/Smileys/classic/waytogo.gif) I somehow melted my pants on the exhaust right under the heat shield (with the heat shield installed)... how? I have no idea...
Holden
« Reply #63 on: March 12, 2009, 03:01:36 PM » |
Maybe it happened while you were off the bike?
OstOgBajer
« Reply #64 on: March 12, 2009, 03:06:13 PM » |
No... the melted part on the pants is on the inside of the leg... I must have been standing in a weird position holding the bike up straight at the gas station or something...
hamsandwich
« Reply #65 on: March 13, 2009, 08:30:38 AM » |
the holes on the other side of mine arent countersunk... I swapped right/left riser parts and rotated them. The result was almost no spacer requirement, but only almost - so one is on. You'll need 30mm bolts instead of the 25mm you have now (riser to fork clip connection) You'll also need to raise the clip ons a little for them to clear the fork tops.
i love people, i just like it better when they're not around...
hamsandwich
« Reply #66 on: March 13, 2009, 08:33:10 AM » |
yah my pants havent touched it anyway...there is a ton of heat coming from the engine in general...nothing bad tho. im hoping the sport classic clipons dont need 2 spacers... the holes on the other side of mine arent countersunk...
hamsandwich
« Reply #67 on: March 13, 2009, 02:00:46 PM » |
ground off the passenger rearsets today, homemade hackjob style........
DucatiTorrey
« Reply #68 on: March 13, 2009, 02:41:59 PM » |
picspicspicspicspicspicspics!
- real place
OstOgBajer
« Reply #69 on: March 13, 2009, 04:26:58 PM » |
How do you make a post like that without pics?! It shouldn't be allowed!!!
grandpa nate
« Reply #70 on: March 13, 2009, 06:08:40 PM » |
+10000000000000000000!!!!!
hamsandwich
« Reply #71 on: March 17, 2009, 09:21:02 AM » |
causeofkaos
« Reply #72 on: March 17, 2009, 12:55:57 PM » |
swingarm doeesnt look half bad with that out of the way..
Favorite convo i read on this board "PICS OR IT DIDNT HAPPEN" "F**K U IT HAPPENED"
Suzuki Blvd M109R " Sliver " = assassinated by cager PW 696 " Pearl " = traded in M1100 " Loki " = Viking God of mischief ( Goddess in this case ) Life is not a journey to the grave with the intention of arriving in a pretty pristine body, but rather to come in sliding sideways all used up screaming F*CK YEAH WHAT A RDIE!!
dutchy73
« Reply #73 on: March 17, 2009, 03:57:25 PM » |
more pics! Can you take a couple close-up's of the hacked area? Looking to see if it's possible to do this and make it super clean. I assume you will be powder coating these now? And can you take a full side profile pic? Would love to really get a solid idea of what this looks like, now that the swingarm is totally exposed.
Overall, nice job!
'09 696 Dark, Termi, Rizoma, CRG
DucatiTorrey
« Reply #74 on: March 18, 2009, 03:07:50 AM » |
Kudos Ham for being the Guinea pig! looks pretty good! ![waytogo](http://ducatimonsterforum.org/Smileys/classic/waytogo.gif)
- real place
