How do I raise the rear end
Started by Kovner, May 13, 2008, 04:10:37 PM
Kovner
Blah I've been so confused lately.
How do I raise and lower the rear end?  By adjusting the tie rod?  How do I do that?
fasterblkduc
Yes. Loosen the jam nuts, (one is left hand thread) and then turn it. It's that easy.
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
Kovner
Quote from: fasterblkduc on May 13, 2008, 04:58:56 PM
Any trick to getting a wrench in there?  There doesn't seem to be much room to get a wrench in there.
Capo
The threads on the tie rod are not lubricated at the factory and can sieze. If you have any difficulty in rotating the shaft, you will be best advised to remove the rod and hold it in a vise. Take a measurement (eye to eye) first then strip the rod, clean and lube the threads with anti sieze, re-assemble and set the length to the distance you measured plus the amount you wish to increase.
Further adjustments can be made with the rod installed.
Capo de tuti capi
Kovner
So do I remove the rod?
The allens at the top and bottom?
Do I need to raise the rear end?
fasterblkduc
If you want to remove the adjuster then yes, support the rear of the bike. I recommend supporting the rear but don't put excessive lift while supporting. In other words, you want to just support it not lift it up. Leave it close to the way it sits when there is no load on it. This will make removing, and replacing the bolts easier because you won't have to fight as hard to align everything.
You could do this by using jackstands on the rearset assy., or by supporting the rear of the frame by some creative method like a rope thrown over a tree branch or something...you get the idea.
If you have a front stand, now is the time to use it. You want to stabilize the front if possible since you'll be moving the back around so much. It would be too bad if you dropped it!!
Atomic Racing
2010 partners:
LA
I did mine like Capo said. Just make sure to measure the ride height at a point that you can use after the adjustment to verify how much you changed the ride height.
I put mine up 1" in the rear and lowered the front 3/8".  Well worth the effort.
LA
scooby
Quote from: Kovner on May 13, 2008, 05:05:47 PM
[laugh] [beer] [laugh] Been there done that...
What would ScoobyDoo?
MonsterMan1036
#8
It's a 19mm wrench you need to use, I ground mine down to fit in the swing arm mount. Looks like this:
forgot pic ???
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
desmobloke
If you need to remove your tie rod to adjust it, or replace the solid one for an adjustable as I did, the bike can be supported by securing a scissor jack between the wheel and frame. With the bike in gear, the wheels chocked and the side stand lashed (and plenty of caution) no other support is required, I found the whole thing to be pretty stable. The spacing can be easily adjusted to make fitment easy, and the job can be done in the yard with no special tools. I pulled this off but don't try to sue if it goes belly up... Cheers
Ahh! Summer changes everything. BARMAN!
