Vinyl-wrapped forks question... (now with finished pics!!)
Started by Rameses, February 02, 2009, 07:53:34 PM
DucHead
And explain how your well refined aesthetic is going to deal with that silver subframe.   ;D
Rameses
Quote from: pompetta on February 05, 2009, 12:14:42 PM
[cheeky]
DucHead
Oldfisti
Quote from: Rameses on February 05, 2009, 12:07:04 PM
I ordered the 3M Controltac in matte black.    [evil]
The parts I'm getting powdercoated are being done in a semi-gloss black.
I'm getting the top and bottom triples, handlebar clamps, front fender mounts, rearsets and passenger peg brackets, rear spring, rear suspension rod and rocker arm done.
And I'm gonna wrap the rear shock body in black vinyl too.
I think it'll look pretty sick when it's all done.   ;D
[popcorn]
Don't forget pics!
ghosthound
How do you guys wrap the forks?  Do you take the wheel off?  I had some leftover vinyl and tried it before but I could never get it on nicely.
DucHead
Quote from: ghosthound on February 05, 2009, 03:20:44 PM
Well, I've not done this, but you certainly have more room to work with the wheel and fender removed.
JTMOTO
Where did you order it form?  How much and idid you have to buy a whole roll?  Definitely post some pics when you finish.
Rameses
Quote from: JTMOTO on February 07, 2009, 02:54:55 PM
I ordered it off ebay.
The stuff I got comes in sheets and there're 50 sheets in the lot that I bought and it was a little over 40 bucks shipped.
After I get my hands on it and see how many sheets it takes me to wrap my forks, I'll probably sell off the rest of it in lots of sufficient size to wrap a set of fork legs with enough extra to allow for some trial and error.
bmonty72
[DING]  Just added to watched threads!!! [thumbsup]
Chchadder
Quote from: Rameses on February 07, 2009, 06:30:44 PM
I'm down for picking some of that up off you, and so is HeMan I'm sure.  Let me know when you finish the job.  I'll most likely just pick up enough from you for two bikes.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
w7ck7d
09' 696 Black
94' BRONCO 5.8 EB
Rameses
I'll consider these pre-orders.
Y'all're first on the list.   [laugh]
Eddie_322
what size sheets did you get? I wouldn't want to have to use more then 6 sheets. One for each fork leg below the bottom triple, one for each for leg between the triples and one each for any of the fork leg shown above the top triple clamp.
I would look for a roll that will allow you to do the  fork leg below the bottom triple in one piece, that way the only seam is the length of the fork tube and I would hide that on the back of the fork leg.
herm
can anyone point the way to some pictures of this mod?
i am having a hard time conceptualizing it
thanks!
No more Monster.
JTMOTO
I spent a while trying to do this and I ended up giving up.  This is difficult to get to look good IMO.  The forks taper and the vinyl has to stretch obviously.  Just my .02 but I rank this very difficult.
