January 10, 2025, 05:49:29 PM
Vinyl-wrapped forks question... (now with finished pics!!)
Topic: Vinyl-wrapped forks question... (now with finished pics!!) (Read 24164 times)
Rameses
*Your Mom* has a Hypermotard
February 02, 2009, 07:53:34 PM »
Pics added on page 4.
I have my bike torn apart right now to get a bunch of stuff powdercoated and am planning to do the vinyl wrap deal while I'm at it.
I'm pretty sure there're a couple of people here who've done this before, so here's my question to you...
Did you wrap the vinyl on the entire fork tube and then slide them through the triples or is the vinyl only applied up to the edges of the triples?
I'm trying to decide what the best way to do this is going to be.
Last Edit: March 17, 2009, 10:56:28 PM by Rameses
Oldfisti
My mom says I'm a catch.
Re: Vinyl-wrapped forks question...
February 02, 2009, 08:23:42 PM »
Do it after or the wrap will interfere with the triple when you try to slide the fork through.
Rameses
February 02, 2009, 09:22:41 PM »
Quote from: alfisti on February 02, 2009, 08:23:42 PM
That's what I figured but I haven't bought the vinyl yet, so I didn't know if it was thin enough to get it through.
w7ck7d
The DUCtOr
February 02, 2009, 10:18:16 PM »
Where can you get the vinyl wrap?
09' 696 Black
94' BRONCO 5.8 EB
Rameses
February 02, 2009, 10:42:32 PM »
Quote from: w7ck7d on February 02, 2009, 10:18:16 PM
Ebay or any sign shop.
MotoCreations
February 02, 2009, 10:49:53 PM »
(clarification) Wrap it
after
the fork blades are installed in the triples. You really do not want the vinyl within the clamping surface area between the two -- it will eventually move as it is a poor shim material at best.
Last Edit: February 02, 2009, 11:46:48 PM by MotoCreations
me:
www.MarkSavory.com
work:
www.MotoCreations.com
daily:
www.FaceBook.com
Rameses
February 02, 2009, 10:52:38 PM »
Quote from: MotoCreations on February 02, 2009, 10:49:53 PM
Wrap it after. You don't want the vinyl within the clamping surface itself -- it will eventually move. (plus you probably do have enough room to get it in there anyways!)
Wait, probably
do
have enough room?
Did you mean to type "probably don't"?
w7ck7d
The DUCtOr
February 02, 2009, 11:11:01 PM »
Ok thanks..this will be my next project this week..
update with pic pls..
09' 696 Black
94' BRONCO 5.8 EB
eichh
February 03, 2009, 04:53:54 AM »
You will want to use a "cast" type of vinyl it conforms allot better and you shouldnt have any problems Oracal 751 or 851 would be a good product a lesser grade may eventually crack due to the tight bend,heat and weather. Im going to do mine also but cant decide on carbon fiber or plain black. My .02
cbartlett419
February 03, 2009, 05:19:28 AM »
3M controltac vinyl is air release and is easier to work than calendered vinyl. Oracal makes an equivalent, but the 3M is a better product. it's available in a nice spectrum of color
Jarvicious
The guy in my avatar wants your
Balls
February 03, 2009, 09:07:51 PM »
Maybe a stupid question, but why not have the tubes powdercoated while you have everything apart? I know you'd have to take out the cartridges and lowers and such, but I feel like it would look so much better than plastic wrap.
We're liberated by the hearts that imprison us. We're taken hostage by the ones that we break.
Rameses
February 03, 2009, 09:27:50 PM »
Quote from: Jarvicious on February 03, 2009, 09:07:51 PM
And then have the triples bored to make room for the powdercoat which might then crumble inside the triples and eventually loosen?
No thanks.
DucHead
No garage queens
February 04, 2009, 05:42:44 AM »
Quote from: Rameses on February 03, 2009, 09:27:50 PM
No thanks.
Powdercoating is too thick for this application.
Choices are vinyl wrap or hard-anodizing. The former is a really nice alternative to the latter because there is a wider variety of color choices, it's (comparatively) easily reversible, does not require fork tube disassembly, does not require special tools/equipment, and it's less expensive.
"45"
Oldfisti
February 05, 2009, 11:23:36 AM »
Personally, I still prefer black cloth tape. (hockey tape)
The matte/flat finish makes it look tough.
Rameses
Reply #14 on:
February 05, 2009, 12:07:04 PM »
Quote from: alfisti on February 05, 2009, 11:23:36 AM
I ordered the 3M Controltac in matte black.
The parts I'm getting powdercoated are being done in a semi-gloss black.
I'm getting the top and bottom triples, handlebar clamps, front fender mounts, rearsets and passenger peg brackets, rear spring, rear suspension rod and rocker arm done.
And I'm gonna wrap the rear shock body in black vinyl too.
I think it'll look pretty sick when it's all done.
Last Edit: February 05, 2009, 12:12:46 PM by Rameses
