April 27, 2024, 02:34:13 AM *
Pages: 1 [2]   Go Down
Author Topic: clutch slave cylinder replacement  (Read 11527 times)
Gimpy
Not quite a
« Reply #15 on: February 10, 2009, 12:14:57 PM »
Well then.  I guess I'm off to bleed my clutch a year later.   Undecided   Thanks for the heads up.     chug
krista
... does she have a
ducati addict
« Reply #16 on: February 11, 2009, 12:53:04 AM »
Here's the install "helper sheet" that we ship with the clutch slave cylinders we sell:
http://www.ca-cycleworks.com/media/yoyo_clutch_install.pdf
Smiley Chris
MAXdB
« Reply #17 on: February 14, 2009, 12:50:33 AM »
One last question for you guys..
after doing the swap to an aftermarket clutch slave..I love it--less work to pull the clutch, simpler to be smooth on gear changes, and neutral is easier to find but the only thing is that after I installed it I had to adjust my pazzos out one notch to make up for the extra distance needed. I also noticed however, that the first 1/2-3/4 inch of pull doesnt do much. So my question is can I adjust this little screw thing ( http://ducatimonsterforum.org/index.php?topic=7428.0 ) to take up the slack/lessen the freeplay just a little without fear of damage of some sort? Thanks again guys  [moto]
Ddan
Some of my best friends are whores
« Reply #18 on: February 14, 2009, 02:57:49 AM »
You may be able to get some adjustment using that screw, but if you go too far you will eventually lose your clutch.  That little bit of free play doesn't sound excessive.
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
« Reply #19 on: February 14, 2009, 05:07:58 AM »
1 - 1.5 mm play at the push rod.  As Dan said, to tight = slippage.
Pages: 1 [2]   Go Up
