dragonworld.
« on: February 08, 2009, 12:44:24 AM » |
After doing my fork oil and replacing of the head stem bearings, I found that I marked the position (for reassembly) of everything except the headlight ! Doh ! So does anyone have the local spec for the correct aiming thereof please .
Jukie
I need a
Paradise
« Reply #1 on: February 08, 2009, 01:29:45 AM » |
uuuummmm straight ahead
Before Honda CB125N Suzuki GS125 Now. Ducati 620ie Lambretta Li150 Ducati S4RT
Dockstrada
« Reply #2 on: February 08, 2009, 01:31:41 AM » |
After doing my fork oil and replacing of the head stem bearings, I found that I marked the position (for reassembly) of everything except the headlight ! Doh ! So does anyone have the local spec for the correct aiming thereof please . For what Bike
If I wasn't who i was, I wouldn't be who I am !
Dockstrada
« Reply #3 on: February 08, 2009, 01:42:35 AM » |
In any case you can down load the user manual from the Ducati owners manuals on oz monster portal in FAQ's
« Last Edit: February 08, 2009, 02:22:19 AM by Dockstrada »
dragonworld.
« Reply #4 on: February 08, 2009, 02:06:05 AM » |
brad black
« Reply #5 on: February 08, 2009, 04:13:20 AM » |
the spec i think is for the top of the low beam cut off to be 9 / 10ths of the height of the headlight centreline at 8 metres away. i usually use 675mm from the ground at 8 metres away as a std.
dragonworld.
« Reply #6 on: February 08, 2009, 01:42:03 PM » |
Thanks all. Thats a better one Brad, finding a flat 8 to 10 metres is the problem. I'll do it at work tonight in one of the train service sheds (150 metres noooo problem. ) Looked at my owners manwell last night for the first time (Only had the bike nearly 2 years, ) And thanks for your eloquent and informative assistance Jukie.
Jukie
I need a
Paradise
« Reply #7 on: February 08, 2009, 02:53:43 PM » |
i aim to please
Dockstrada
« Reply #8 on: February 08, 2009, 03:01:25 PM » |
i aim to please
And you do
dragonworld.
« Reply #9 on: February 08, 2009, 03:13:07 PM » |
And you do Posalootly !!
Jukie
I need a
Paradise
« Reply #10 on: February 08, 2009, 03:17:00 PM » |
hey vince you should of come for a swim with me, i was very cold in the water. talking about headlights
dragonworld.
« Reply #11 on: February 08, 2009, 03:26:06 PM » |
Hi Beam or Low Beam??
Jukie
I need a
Paradise
« Reply #12 on: February 08, 2009, 03:30:40 PM » |
very high beam.
dragonworld.
« Reply #13 on: February 08, 2009, 03:34:48 PM » |
very high beam.
Oh dear!! Me legs have gone all jelly like and weak,
Jukie
I need a
Paradise
« Reply #14 on: February 08, 2009, 03:37:53 PM » |
yes but since then i got a bad case of sunburnt and have to not where a shirt
