September 29, 2024, 12:11:02 PM
99 750 Suspension Improvements?
Topic: 99 750 Suspension Improvements? (Read 3766 times)
Sgt_H
May 13, 2008, 08:09:26 PM »
Hi all, The budget for bike parts is slim right now (no Ohlins
), but I'm looking for ways to improve my suspension performance. I bought the bike used with few records so I have no idea if/when the front fork oil was changed, so that is high on the list. Is there anything I can do on a tight budget while I have the forks apart to make improvements? I've seen threads on springs and valves but I don't know what either of those would run pricewise. Is changing the oil the best I can do without serious outlays of cash?
Is there anything that can be done with the stock rear shock?
Thanks
Sgt_H
Banned
Re: 99 750 Suspension Improvements?
May 13, 2008, 08:17:23 PM »
How slim's "slim"?
New springs will run a couple of hundred or less, and _will_ be worthwhile.
There's not a lot else you can do to these forks anyway - Brad Black's advice is "put 0.9 springs and 10wt oil in, that's as good as they'll get".
If the oil's _old_ old, just replacing it will help, but you'll likely still be a little undersprung (unless you're well under 200lbs).
big
Last Edit: May 13, 2008, 08:19:36 PM by bigiain
my personal website
my less personal (I'd stop well short of calling it "professional") web site
Sgt_H
May 13, 2008, 08:32:29 PM »
Well, the wife wouldn't like it but I could probably swing a couple hundred. I did just spend $300 on an exhaust though.
Eh, give it a month and I'll be able to justify it. I'm 185 pounds now, but I'm hoping to get closer to 200 over the summer. I know close to nothing about suspension. Do you think that .9 springs are right for someone in the 190-200 puond range?
Is there anything that can be done for the rear? Or will that just have to wait until next year when I can replace it?
Thanks for the help bigiain
Sgt_H
Banned
May 13, 2008, 10:18:03 PM »
Quote from: Sgt_H on May 13, 2008, 08:32:29 PM
Here you go, Racetech will sell you a pair of springs for $110
here
Their spring rate calculator (linked off that page) suggests you probably should go for .85kg/mm for street riding. They'll sell you the right rate rear spring for $110 as well, and a revalve kit for the boge shock for $190 (though you'll need to get a properly set up shock place to fit that to your shock, that's not a home job for most of us, you need ~200psi worth of nitrogen to regas it...)
big
my personal website
May 13, 2008, 10:59:19 PM »
Don't go by RaceTech's calculator for rear springs, it's goofy.
0.85 is a little on the light side for you at 185, especially if you're targeting 200 for summer.
Depends how you ride and how bad the roads are too.
Sgt_H
May 14, 2008, 04:59:35 AM »
Quote from: bigiain on May 13, 2008, 10:18:03 PM
here
Awesome, thanks for the link. That makes this much more doable.
Quote from: Speeddog on May 13, 2008, 10:59:19 PM
I put in 200 punds and it still gave me .856. What would you recommend? .9?
Sgt_H
Banned
May 14, 2008, 05:05:14 AM »
Quote from: Sgt_H on May 14, 2008, 04:59:35 AM
I would.
I have .85 in my bike and I'm 175.
Springs sag over time.
May 14, 2008, 10:09:54 AM »
Just to clarify:
RaceTech calculator for front springs seems to be pretty good.
rear
springs seems to be fuxored.
Sgt_H
May 14, 2008, 01:54:01 PM »
Quote from: Speeddog on May 14, 2008, 10:09:54 AM
Just to clarify:
rear
Question for you on the rear... The Racetech page says this, "Ideal Rider Weight for the Stock Spring 230 lbs or 105 kg" and gives me a recommendation of an 8.5 kg spring, with stock being 9.4. I think the rear is already kind of soft but it's telling me to go softer. Is there another calculator out there? What would everyone else recommend for a 190-200 pound rider?
Sgt_H
Banned
May 14, 2008, 04:02:55 PM »
That confirms it's still fuxored.
About 10 kg/mm should be good for ya.
May 14, 2008, 04:12:21 PM »
Quote from: Speeddog on May 14, 2008, 04:02:55 PM
I'm 175 in street clothes and that's what I have.
May 14, 2008, 04:59:57 PM »
Quote from: ducpainter on May 14, 2008, 04:12:21 PM
Dangit. My mistake, chart was for geared weight.
Thanks, DP.
So 200# rider, with no gear, 10.5 kg/mm.
Just to clarify for the future if the OP's info gets lost, this is for the early '851' style hoop suspension.
Sgt_H
May 14, 2008, 05:02:19 PM »
Thanks for the help guys. I think I'll have a nearly new bike, or at least new feeling bike, by the end of the year.
Sgt_H
Banned
Privateer
June 21, 2008, 03:42:12 PM »
front springs are my next bike part I'd like to fix (04 620). I'm about 215 out of the shower, and the racetech calc gives me this:
FRONT FORK SPRINGS
Recommended Fork Spring Rate for Street: 0.878 kg/mm (use closest available)
which would be either of these
RT FRK SPR 35.5x33.5x270 .85kg
RT FRK SPR 35.5x33.5x270 .90kg
I'm thinking I should bo with the .90? Any opinions to the contrary? I ride 100% street.
thanks
Andy
Reply #14 on:
June 22, 2008, 09:49:22 AM »
At 215, I'm thinking you'll need more than a .90.
Lemme check my charts on monday, shoot me a PM if I forget.
