December 27, 2024, 02:09:01 AM *
Author Topic: my M695 w/mods  (Read 2927 times)
woodyracing
« on: February 09, 2009, 11:08:44 PM »
I can't sleep so I figured I'd post up some pics of the mods I've done semi-recently
mods:
Adjustable rear right height linkage from another Ducati ($15 gotta love ebay!)
14T Vortex front sprocket
Changed to reverse shift (flipped the linkage, no fancy direct mount lever here lol)
Fender eliminator (not sure of brand but it was free!)
Welded on swingarm spool adapters (thanks to Melillimoto in Ocala, FL for the welding!)
Painted the rear shock spring red (turned out awesome!)
Aftermarket oil drain plug (stronger magnet, hex head, safety wire holes)
Termi High Mounts, DP ECU, open airbox
RAM GPS mount for my TomTom with a new wiring job.  For starters I used a battery tender connector for the "GPS Harness" I made, so that it can plug into the battery tender connector already on the bike.  That keeps the wiring low key and allows fewer wires to have to be run back to the battery.  The + wire goes to the GPS car adapter's circuit board inside a very small weatherproof "project box" similar to the ones found at radio shack.  The (-) from the battery tender connector runs through a pressure switch on the RAM mount that is activated only when the GPS is installed in the cradle, then runs back to the project box.  The project box is mounted on the front of the airbox (can't be seen unless your REALLY looking for it) so the charge cable for the GPS only had to be about 6" long.  I have one of the little rubber wiring strap on the from on the right side so the connector can be held out of the way when not in use.  This contraption has several benefits, the switch on the cradle ensures the adapter is only powered when the GPS is actually being used.  The entire "harness" can be removed in a matter of seconds with no trace it ever existed.  Honestly I don't use my GPS at all while in Florida and only use it back home when doing group rides but I was bored a few weeks ago and this is the result lol.
Just did the 2-year service including shimming the swingarm properly (it was way off) adjusting the trim, thicker fork oil w/preload spacers, and a few other misc items.  During this process I discovered bad valve guides just in time to have it replaced under warranty so Melillimoto in Ocala, FL took care of that (I can't recommend Melillimoto enough, a true model of what service should be)
hcomp
All this time I wondered what it was like to have a
Nothing to see here
« Reply #1 on: February 10, 2009, 12:11:47 AM »
Thats a purdy 695!
にもかかわらず、私の車は本当に速いドライブ、私は女性の生殖器のようなバイクに乗る
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
« Reply #2 on: February 10, 2009, 05:57:02 AM »
Realy nice waytogo
« Reply #3 on: February 10, 2009, 08:44:23 AM »
is it the angle of the photo or is your exhaust jammed between your swingarm and rearset? seems AWFULLY tight.
woodyracing
« Reply #4 on: February 10, 2009, 09:01:15 AM »
its clear at the full stroke of the shock, just close.  It did rub there at one point but I took care of that
Jaman
« Reply #5 on: February 10, 2009, 10:02:43 AM »
Nice!  waytogo
On the GP shift, the "direct mount" lever cleans up shifting/more positive engagement, as it takes away the "slop" created by the linkage, IMO.
I flipped my linkage as soon as I bought my bike, as i have run GP pattern on my street bikes for many years, and bought something simliar to this
http://www.slingshotracing.net/catalog/ducati-parts-billet-aluminum-c-9_3.html?page=3&sort=2a
the "shorty" one...  I think a board sponsor may have them as well, but closer to $100, and probably a little nicer to boot.
Two dogs
« Reply #6 on: February 10, 2009, 01:01:39 PM »
Any chance of a close up of your gear changer setup ?
Also do you know which model bike your  adjustable linkage originated from ?
 nice ride 695 pride  waytogo
cheers
dez
woodyracing
« Reply #7 on: February 10, 2009, 01:29:56 PM »
don't think I have a picture of the linkage, I'll try to get one later.
IIRC the adjustable linkage was from a 749/999, but if you get one make sure the heim joints aren't locked up before installation.  I still spray a bit of WD40 on mine occasionally.  Also keep in mind a little bit of adjustment goes a LONG way.
woodyracing
« Reply #8 on: February 10, 2009, 02:34:52 PM »
here we go:
two things to look out for
1.  make sure your linkage isn't going to hit the stator cover when you shift
2.  the stock rod will just barely fit, but I did get it to work fine
