January 10, 2025, 12:48:41 AM *
News: Please Help
Author Topic: Lengthening handlebars  (Read 1042 times)
fletch696
« on: February 10, 2009, 07:00:03 AM »
So I have an 09 696 and I like the windscreen.  I purchased a set of Rizoma 22mm bars.  They have worked on other 696, but with out the windscreen.
Is there any safety issues I should worry about with adding a little length to the handlebars.  I only need to add about 1/4" to each side of the bars to clear the fairing, but I will add 1/2" to the end of each side.  My thought is to have some aluminium machined down so that it fits inside the hollow end of the bar, and has the same outside dia as the bar.  Thoughts?
« Reply #1 on: February 10, 2009, 08:42:02 AM »
why don't you look at some of the other options for windscreens. I know Barracuda has one and there are a few others, including one in france.
« Reply #2 on: February 10, 2009, 10:41:38 AM »
i have that....made of plastic, its called a barend slider. :p you shoudlnt have any issues.
fletch696
« Reply #3 on: February 19, 2009, 06:37:41 AM »
Update:
I took the bars to the local machine shop and had them add 2 inches to each end of the bar.  The extension at the end of the bar is solid aluminum and extends into the bars by 1.5 inches.  I think that this will work nicely.
Chchadder
« Reply #4 on: February 19, 2009, 08:51:06 AM »
Wow, two inches on each side?  Hope you're not planning on lane splitting...
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
fletch696
« Reply #5 on: February 19, 2009, 03:04:40 PM »
I just went out to the garage and measured the end to end distance of the factory bars... about 31 inches.  The extended bars measure just under 31 inches.  so I don't think that they are too wide.  And lane splitting in Indiana is not legal.
Chchadder
« Reply #6 on: February 19, 2009, 03:21:55 PM »
It's not legal in many places, but... Grin
That's cool that the bars measure up to the stock length now, so no worries!!
