January 10, 2025, 12:45:14 AM *
Author Topic: Power Commander V  (Read 1869 times)
« on: February 13, 2009, 01:10:24 PM »
Where is the best place to order the powercommander V for the 696?
I have ordered a BCM air filter and will be getting the roads italia exhaust ordered this week, so i figured it will need the PC V setup for the bike.
any thoughts?
MadDaddy
'09 M696, '98 RS250
« Reply #1 on: February 13, 2009, 01:50:46 PM »
Best price I've seen. Raux, I bought the Exans! Schweeeet!  [moto]
http://www.kneedraggers.com/details/Dynojet_Power_Commander_V_Ducati_696--641426.html
2009 M696, 14T front sprocket, M1100 bars and riser, DP bar ends, CRG levers, R&G tail tidy, Exan carbon fiber exhaust cans, DP low profile seat, 12v port for charger and TomTom, Motovation frame sliders, axle sliders and fork sliders. LH Euro air shroud with charcoal canister removed. GIPro gear indicator. Rizoma rearsets.
1313
« Reply #2 on: February 13, 2009, 02:06:02 PM »
The Auto Tune module seems nifty.  popcorn
09 M696
« Reply #3 on: February 13, 2009, 02:22:54 PM »
was thinking the same.
less work to do on the tuning.
i think though that with some experimenting and my laptop connected i could come up with a decent map without it.
« Reply #4 on: February 13, 2009, 03:26:25 PM »
Did you see the Juice Box from Two Bros?
09 M696
danaid
« Reply #5 on: February 13, 2009, 10:47:35 PM »
  It's good to see new parts coming out for the new monsters. Luckily my Ducati dealer has a dyno and installs power commanders. In a year or so when I have my 1100 hopefully there will be some good custom maps available for purchase.
« Last Edit: February 13, 2009, 10:49:48 PM by danaid » Logged
11' 1198SP  Black
09' 1100S    Red
gearhead
« Reply #6 on: February 14, 2009, 08:11:46 AM »
This makes me so happy. I was afraid there never would be a way to mess with the fueling. So what reall y is th e issue with the fueling on the 696? I notice roughness around the 4000 rpm range. Will these modules rectify that issue? What is the dif between the PC and the Juice Box? I'm holding off buying goodies incase I trade up to the 1100.
« Reply #7 on: February 14, 2009, 09:22:46 AM »
maybe i'm wrong, but wouldn't a PC V for the 696 work for the 1100 as well. they are both seimens units. you would only have to change maps.
i will check out the juice box before ordering.
also, this only messes with fueling. is there a system that also works with the ignition timing or is that adjustable separately? guess i'm wondering if it is only the fueling systems that affect the power/roughness. to me adjusting spark and fuel would be the best way to go.
« Last Edit: February 14, 2009, 09:25:04 AM by Raux » Logged
« Reply #8 on: February 14, 2009, 09:45:47 AM »
i was under the impression these PCV units were the same was the PCIIIR for the S4Rs and Hypermotard, only works with a certain RPM range
« Reply #9 on: February 14, 2009, 09:58:33 AM »
apparently the juice box put extra fuel into the system and that's it? so kinda like a fuel map but only up.
the PC V says it can go down 100% ie no fuel up to 250%
z0mb1e_DUC
« Reply #10 on: February 14, 2009, 10:58:53 PM »
PC V has connections for O2 sensors.  I'm guessing that allows it to function in the closed loop portion of the throttle?
'09 m696 Dark
