January 10, 2025, 11:59:27 AM
Cored Exhaust
Topic: Cored Exhaust (Read 12644 times)
Fox
succisa virescit
Cored Exhaust
February 20, 2009, 03:58:26 PM »
I have a 620 and I am thinking about coring the exhaust. My mechanic said the bike will loose a little mid-range power and he did a before and after dyno test with another monster. Anyone have any experience with it? Would you recommend doing it?
2008 KTM Duke 690
needtorque
Re: Cored Exhaust
February 20, 2009, 04:15:21 PM »
Do it you will be fine. Coring only allows for more airflow out but since you are not allowing more fuel/air in the only thing it really affects is back-pressure and 4 stroke engines are not affected too much by that.
Who insures the FDIC?
TiAvenger
Re: Cored Exhaust
February 20, 2009, 04:24:37 PM »
not if he sets the fuel trim correctly. I had it done, for about 85 bucks after I put my cored cans on. Didn't notice any difference negative or positive
Just loud as hell
monstermania
Re: Cored Exhaust
February 20, 2009, 05:44:21 PM »
I had a half core done on my 696 exhaust, it sounds great and there was no negative change. I tried the full core first and they were crazy loud, so I switched for a set of half core and they were just right. Deep, loud and great sounding.
Fox
succisa virescit
Re: Cored Exhaust
February 21, 2009, 05:08:37 PM »
You can half core the exhaust?
2008 KTM Duke 690
monstermania
Re: Cored Exhaust
February 21, 2009, 07:11:48 PM »
Quote from: Fox on February 21, 2009, 05:08:37 PM
Yea, the guy who did mine just took out one baffle instead of all of them. He can tell you more about it, he is on the forums here, screen name ryanracer. He did a great job for me, so you might want to give him a shout.
ScottRNelson
Mr. Dual Sport Rider
Re: Cored Exhaust
February 25, 2009, 04:56:02 PM »
There are three chambers in the typical Ducati exhaust (before the under-tail ones appeared, and the S*R pipes). The exhaust comes into chamber 1, goes through some tubes to chamber 3, goes through some more tubes to chamber 2 in the middle, then out a single tube passing through chamber 3 and out the back. You can cut the tubes in either chamber 2 or 3 to get an improved sound, but not affect back pressure or tuning much. It sounds good, but won't make people deaf. I don't like the fully cored exhaust pipes, personally.
I've cored pipes both ways. On a Monster, it's easier to do chamber 3, because it's hard to get to chamber 2. On most other Ducati exhausts, like the ST2, SS, 851/888, and so forth, it's easier to do chamber 2. Either way will make the bike sound like a proper Ducati.
LA
The Sleek Black Beauty
Re: Cored Exhaust
February 25, 2009, 05:32:15 PM »
Absolutly! Core those cans young man.
And no half way measures either. Go big or stay at home.
LA
MaxPower
Re: Cored Exhaust
February 26, 2009, 08:04:19 AM »
Quote from: ScottRNelson on February 25, 2009, 04:56:02 PM
OK, so when I look into my cored 620 exhaust, I see three open tubes looking back at me. Is that a "full cored exhaust"? (I bought them off someone on TOB)
Either way, it's not that much louder than the stock, and my ass-dyno certainly didn't notice a change in power.
Nobody snuggles with Max Power. You strap yourself in and feel the Gs!
2003 M620i.e.
Autostrada Pilot
Re: Cored Exhaust
February 26, 2009, 08:09:43 AM »
Quote from: MaxPower on February 26, 2009, 08:04:19 AM
Mine are the same way, and I think they sound much louder than stock (but not nearly as loud as no pipes at all). I had db measurements for stock and cored that I had posted on TOB. I think I still have the comparison charts at home.
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
SaltLick
Re: Cored Exhaust
February 26, 2009, 08:59:34 AM »
I cut mine back so they are 11" long total length. I popped the ring out as well. Ive heard that is what makes the biggest difference in sound is popping that ring out (well its not as easy as it sounds, you have to grind the welds off to be able to smack it out with a hammer) so half core is leaving that ring in full cored is taking that ring out.
ScottRNelson
Re: Cored Exhaust
February 26, 2009, 09:07:15 AM »
Quote from: SaltLick on February 26, 2009, 08:59:34 AM
Not quite. Generally, "fully cored" means removing all of the internal chambers. If you leave chambers 1 and 2 unmodified and just remove everything in chamber 3, the back chamber, including that ring, it would be consider "half cored".
SaltLick
Re: Cored Exhaust
February 26, 2009, 12:33:28 PM »
Quote from: ScottRNelson on February 26, 2009, 09:07:15 AM
hmm guess mine is half cored then. I think if i look in mine i see three chambers.....oh well its loud enough for me.
ScottRNelson
Re: Cored Exhaust
February 26, 2009, 01:16:10 PM »
Quote from: SaltLick on February 26, 2009, 12:33:28 PM
If you look into yours, you will see three tubes going into one chamber. The chambers are separated by flat sheet metal.
SaltLick
Re: Cored Exhaust
Reply #14 on:
February 26, 2009, 01:25:52 PM »
Quote from: ScottRNelson on February 26, 2009, 01:16:10 PM
Doh! thats what i meant to say three tubes. So past that flat sheet of metal there is two tubes you are saying, so at that point once you get it back to two tubes its a full core or do you need to cut the tubes back til you get to the next sheet?
I think ill stop showing the world how dumb i am now.
Last Edit: February 26, 2009, 01:27:24 PM by SaltLick
