January 10, 2025, 01:19:49 AM
Please Help
Aftermarket option for fuel pump to fuel line quick disconnect fitting?
Topic: Aftermarket option for fuel pump to fuel line quick disconnect fitting? (Read 2773 times)
Chchadder
February 21, 2009, 02:55:51 PM »
Has anyone else here applied just a bit too much pressure the wrong way when removing the 90 degree quick disconnect fitting from the fuel pump? And then find out that the local dealership is out of them until Friday? Yeah, me too...
Anyone find any aftermarket or other solutions to replace this somewhat flimsy part?
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
Re: Aftermarket option for fuel pump to fuel line quick disconnect fitting?
February 21, 2009, 04:21:05 PM »
http://cgi.ebay.com/ebaymotors/New-Quick-Disconnect-Fuel-Fittings-Ducati-and-Triumph_W0QQcmdZViewItemQQitemZ310088800491QQptZMotorcyclesQ5fPartsQ5fAccessories
but youll need to rethread the pump end.. lol
Last Edit: February 21, 2009, 04:23:05 PM by He Man
Chchadder
February 22, 2009, 02:58:49 PM »
Quote from: He Man on February 21, 2009, 04:21:05 PM
And in that vein, has anyone threaded the pump end to accomodate something like these (there is a 90 degree option available)?
http://ferracci.com/store/cart.php?m=product_detail&p=287
DucHead
No garage queens
February 22, 2009, 03:05:49 PM »
omega.com has all kinds of quick disconnects
"45"
Chchadder
February 22, 2009, 04:04:39 PM »
So does Colder, but they are pretty much all threaded or substantially different from this particular application.
dlearl476
February 24, 2009, 07:06:33 AM »
Quote from: Chchadder on February 22, 2009, 04:04:39 PM
An alternative might be a thread to barb adaptor with a short length of hose to a barb fitting QD. Sometimes that puts the QD in a more accessible place anyway.
Thanks for the FBF link, man. I just ordered some QDs for my M900.
fasterblkduc
February 24, 2009, 07:50:07 AM »
I just cut the fuel lines somewhere in the middle of the span, and put in a straight barb fitting. Then when I want to remove the tank, clamp off the line just above the fitting, remove my hose clamp from the barb fitting and you can pull the line off easy as pie. it will cost less than five dollars for the fittings and hose clamps at H-Depot.
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear
, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
February 24, 2009, 08:15:03 AM »
Quote from: fasterblkduc on February 24, 2009, 07:50:07 AM
thats a good idea and much simpler, just that chcader's bike already has 1 damaged connector. i think ill go your route next time. seems much simpler.
February 24, 2009, 10:53:39 AM »
aren't there quick connects that shut off when disconnected. would eliminate the need for the clamp on the hose perhaps weakening that hose.
fasterblkduc
February 24, 2009, 01:47:54 PM »
Quote from: Raux on February 24, 2009, 10:53:39 AM
Yes there are. This is just a much cheaper fix. When you clamp the hose, it doesn't take too much pressure. If you are easy on them, they will be just fine.
Atomic Racing
2010 partners:
Komodo Gear
