February 24, 2025, 03:42:36 AM *
News: Please Help
Author Topic: Carbon fiber grades  (Read 3227 times)
uclabiker06
"The time you enjoy wasting isn't wasted"
« on: May 14, 2008, 08:50:36 AM »
Hello,  curious to know what exactly do the terms "wet-lay" & "pre-preg" referr to? Thanks in advance
2006 S2R
2009 Smart
Omnipotent Potentate
Personal Pretext
« Reply #1 on: May 14, 2008, 01:28:45 PM »
Pre preg will generally be better.  The fiber mat comes permeated with the epoxy binder, the result is a more even finish and a stronger part.  Wet lay is how you would think of someone creating a fiber glass part.  The fiber mat is laid down then the binder is poured or brushed over it.  As a result the application can be less even that the pre-preg and cause weak spots and an un even finish.
Spy+
« Reply #2 on: January 18, 2013, 05:31:26 PM »
What about when the vendor mention "3X" ?
SF 848
M696
Can am spyder gsr
JoeB
The Desmo Deuce
Desmo Deuce MS4
« Reply #3 on: January 20, 2013, 01:21:41 AM »
could mean anything.
3x layers, or the twill might be 3x3 but in reality it means naf all for a non structural piece.
Most CF used for cosmetic pieces is constructed from a 225g/m 50/50 weave. Whether it's pre-preg or wet layup means bugger all if the part is vacuum bagged. However, if the part is wet laid (resin brushed / rolled in) then the weight will be greater for the same fibre density, because more resin is used.
I'd be more concerned about the CF parts being clearcoated with a UV safe clearcoat, or a UV stable gelcoat used in the mold before the carbon is laid up. Alternatively one can use 'surfboard resin' the top coat which is UV stable and very thin. it's usually poured onto the part and let to run off, then finish sanded when cured.
Many ways of skinning the cat.  lightest part will be an autoclaved pre-preg vacuum-bagged part. Done correctly it will be stronger than others - for the same weight.
Hershell
« Reply #4 on: January 20, 2013, 11:26:58 AM »
You might find this interesting.
2017 Superleggera 1299
2014 Monster 1200S
2013 Panigale 1199R
2016 Yamaha Zuma 50
AmoK
M900Sie 2001
« Reply #5 on: January 21, 2013, 11:53:50 AM »
I'm not sure if this is carbon fiber grade related of just about the finish, but I'll ask it anyway Smiley
I got a M900Sie, that comes with few CF parts. The front fender and side panels are original Ducati CF parts.
The problem is that the aftermarket CF parts that I have been able to find are mostly glossy, as the Ducati parts are not. How can I make these parts match, I'd like to have either glossy or matte pieces on my bike.
Is it possible to sand the parts and finishing them with matte coating?
How about making the matte parts glossy?
Thanks for the help!
-Aimo
________________________
2001 Ducati Monster 900Sie
BoDiddley
S4Rs In Michigan
« Reply #6 on: January 21, 2013, 04:03:10 PM »
Watch out for the junk parts that are glass laminated between CF layers, they even call them wet lay. I just finished a rear fender fit for my S4RS and the company I bought it from forgot to mention anything about the glass but made a big deal out of the wet-lay.  It worked out fine anyhow but it was a rip from them.
"But sire what are we to do.  You have taken all our weapons and now the heathen hordes are at the gate.  Are we to lie down and give them our lives.  Without weapons they will make us eat ourselves."
Kobiashi
« Reply #7 on: January 21, 2013, 07:55:21 PM »
I have some CF parts on my Monster, which I'm considering painting (red) to match the original color scheme.
Is CF paintable?
Hershell
« Reply #8 on: January 22, 2013, 01:32:31 AM »
Lots of good info here....
http://my350z.com/forum/exterior-and-interior/222328-carbon-talk-interested-in-learning-more-about-automotive-cf-parts.html
2014 Monster 1200S
2013 Panigale 1199R
2016 Yamaha Zuma 50
« Reply #9 on: January 22, 2013, 03:20:18 AM »
Is CF paintable?
Yes.
Sometimes there will be defects in the carbon that aren't visible until you start applying paint, but it can be worked around.
Spy+
« Reply #10 on: January 23, 2013, 05:45:22 PM »
Thanks!!
SF 848
M696
Can am spyder gsr
Case S2R
« Reply #11 on: January 25, 2013, 04:49:47 PM »
I am sure it has been answered but
PrePreg = resin already applied to the carbon, typically hardens (forms final shape) with heat (in an oven).
Wet Lay = Dry carbon where the resin is  poured, dabbed, dipped or painted onto the cloth
3X = number of plys/layers, in this case 3 (duh!!!) Smiley
The advantage of pre preg is your layers stay lined up better, for a nicer finish, and the resin ratio stays stable (ex. 30% resin to fiber)  This is the preferred way to build high quality structures and it is WORLDS cleaner than wet lay. And more controllable from a quality control standpoint
The advantage of Wet lay is you have a lot more resin which typically fills pin holes and such and leads to a part that can (sometimes) be faster to prep for paint.  It is also much cheaper to buy and have on hand but resin can get everywhere, I never like doing it.
Fiberglass is sometime substituted as a top layer (or bottom) because it is saves money, clear, sands better, help the mold release...  It all depends on the part, manufacturer, and price point
As for our carbon ducati parts, 99.9% are cosmetic jewelry so as long as you like the look and don't yellow over time you are good to go.  I question if any of it is "real high qualty" (and it does not need to be).  If I hold it to the sun I can see daylight trying to shine through my factory monster carbon fender.  (off of a 2005 S4R).  Yea, it is thin but seems to work just fine.
« Last Edit: January 25, 2013, 04:57:08 PM by Case S2R » Logged
