Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
Ddan
Quote from: TiNi on May 01, 2012, 03:09:21 AM
up early again i see  ;D
it's rainin' here  :P
gotta run! have a day guys!
Yup...went to bed early too.
here too...
later
Ddan
Quote from: Dan on May 01, 2012, 03:17:00 AM
Did the crew show yesterday?
yeah...in a manner of speaking.
Jeff and I went and got some crete mix and poured the piers.
Jim made a lumber list for the porches and ladders and helped pour.
They left at 11.
I continued and applied the DuRock stuff to the foam in the areas the porches will be. There was a learning curve on that I'll tell ya... [laugh]
Then I tore T's car apart.
I got done around 8.
Ddan
Quote from: ducpainter on May 01, 2012, 03:22:36 AM
They left at 11.
Sounds like a pretty productive day.  The Durock, trowel-on stuff?
Quote from: Dan on May 01, 2012, 03:28:43 AM
Yup...B-2000?
handled like acrylic modified grout.
I started using the plastic washers I used on the foam to hold it. Quickly removed the ones that weren't covered and switched to roofing nails to hold the mesh.
Ddan
Quote from: ducpainter on May 01, 2012, 03:34:52 AM
Yup...B-2000?
I've never used anything to cover foam that didn't make me wish I was using something else    [laugh]
Quote from: Dan on May 01, 2012, 03:47:25 AM
You're on your hands and knees scraping shit into the stuff from the ground...yeah...
anything is more fun.
Ddan
Did you get the brakes done?  Enough parts?
Quote from: Dan on May 01, 2012, 04:39:09 AM
No...
and no.
I need e-brake cables, and I have no way to get that far under the thing. I can probably borrow my neighbors ramps.
The system is designed so you can replace cables without removing the drums.
I also discovered a broken stabilizer link.
I gotta call my guy and see if he can do it before he inspects, and how many millions.
