still on my first cup
that is such great news from dave & p :)
morning lethe
going to put the generator in place today, run the liquid-tight from it and into the house and then mount the transfer switch. If I get further than that, all the better.
Quote from: TiNi on December 02, 2012, 04:51:00 AM
morning lethe
It is...
Quote from: lethe on December 02, 2012, 04:54:20 AM
Does it get anchored to a pad or does it just sit there?
Quote from: ducpainter on December 02, 2012, 04:56:09 AM
sitting there should be fine as internally the whole assembly sits on a dampener that is mounted to it's own thick pad.
I'll anchor it later if it looks like it moves at all.
Quote from: lethe on December 02, 2012, 04:59:19 AM
I was thinking more for difficulty of removal.
Quote from: ducpainter on December 02, 2012, 05:11:13 AM
It's over 300 lbs, it will be on the other side of a 6 foot fence, it will have electrical hard wired to it and gas hard plumbed. It would be quite a task for someone to take, plus it doesn't even look like a generator really.
Quote from: ducpainter on December 02, 2012, 05:15:12 AM
Then...
not to worry.
they could always go the route of chopping the gas line with an ax followed by the electrical lines. What could go wrong?  [cheeky]
s.o. wants me to get her 2 boxes labeled xmas accesories that somehow are in MY closet for that I have to move way too much stuff around and don't feel like it . .  xmas? not me!!!
Quote from: lethe on December 02, 2012, 05:18:54 AM
Your description of the set up tells me those electrical lines are only hot when the unit is running.
I ain't scared. ;D
