supposed to snow here too... 6+
on another note...
just called the oil co for emergency service
our boiler is down....
[coffee]
Spitting snow here and its much warmer 18o this morning.
Coffee sounds finished [coffee]
Quote from: TiNi on December 29, 2012, 06:53:23 AM
on another note...
[coffee]
Did they service it this season?
edit...they're calling for up to 6" before it's done here too.
on another note...
[coffee]
bet they respond quicker than my emergency service....me  [cheeky]
Quote from: ducpainter on December 29, 2012, 06:57:08 AM
nope .... and that's my fault
cancelled service to save money
(had lost my job the week before it was scheduled)
i never rescheduled...  :-\
it's a pressure valve issue
Quote from: TiNi on December 29, 2012, 07:08:10 AM
I had to replace that and my circulator pump this past fall.
The thing that always sucks with plumbing related things is that when you replace one thing you often have to replace everything around it as you go to shut a valve that hasn't been exercised in forever and it fails when you touch it  :P
great  :-\
hopefully repair guy will bring lots of parts with him
You might as well have them do the annual service too, or schedule a tune up for regular hours.
It might prevent an issue later this winter. :-\
Quote from: TiNi on December 29, 2012, 07:15:05 AM
great  :-\
they'll most likely be carrying enough on the truck that they could replace anything needed
Quote from: ducpainter on December 29, 2012, 07:15:46 AM
they don't do annual service on emergency calls
have to reschedule that
and after reading ML's OFFS thread i should do the service on the septic as well
I service my sewer line by knocking loose chunky stuff with a length of threaded rod every so often.
If you're out in my garage watch what you grab to scratch your back  [laugh]
eeeeeeew
when i said "i" i meant call the guy  ;)
Quote from: TiNi on December 29, 2012, 07:20:34 AM
Don't put that off.
I doubt you have tile pipe in your system.
A pump out would be a good idea though.
Quote from: ducpainter on December 29, 2012, 07:42:19 AM
Don't put that off.
pump out was done a year and a half ago -
ok, i'm done with the pooper pumping talk  [laugh]
let's switch it back to the weather, k?  ;D
Quote from: TiNi on December 29, 2012, 07:49:10 AM
It isn't time then for that service...
We always talk about the weather...
hardly ever about poop. :P
