The linkage on Superbikes and Monsters are different.
A spring for a 190 lb rider will be a different weight rating for the two bikes.
Put it on and try it.
You'll see.
Quote from: ducpainter on January 17, 2013, 06:04:43 PM
You'll see.
Not gonna spend $250 + S&H to "try out" . . . better keep on looking in bay for sumtin'  . . . ???
Dood...
you get a paycheck...
regularly.
Quote from: ducpainter on January 17, 2013, 06:20:25 PM
Dood...
regularly.
building fence around house . . . wife bought pool . . . my xmas present from me 2 me . . was the rearsets . . .
so, gonna look into Bitubo or Marzocchi . .. they under $600 new
http://www.carpimoto.com/EN/Bike_Ducati_Monster-620/Suspensions-Wheels/Rear-Shocks/7770_D0022XZE01-Bitubo-Rear-Shock-Absorber-for-Ducati-Monster-620.htm
Send your shock to race tech and they can revalve and re spring it for your riding style and weight. Once you have the preload and rebound set you shouldnt have to mess with it again.
http://www.racetech.com/page/id/80
I dont have one on my monster but I guy I rode with did, he liked it alot.
I did have Racetech gold valves and springs in the front of my track bike with a Fox twin clicker at the rear. once it was set up, it all worked perfectly.
Quote from: Mendo Dave on January 17, 2013, 07:12:27 PM
I have the OEM "cheap" Sachs" shock . . . non-rebuildable unit . . . fronts hace racetech springs . .
Im pretty sure that what the guy had just the OEM shock. I'll see if I can find him he used to hang out in tech.
I have 748 forks on the front..
Quote from: Mendo Dave on January 17, 2013, 07:24:45 PM
I was thinking on installing 998 forks on mine but then . .. the 998 came complete to me . ..  so, Monster stays "OEM" front . . except if I get away with installing M696 front forks with radial calipers on mine . . .same rotor, same pn, so, same offset . . . but, is all just a plan . .. legal paperwork on 998 is taking a bit longer than expected . . .
Well if you do it you need to get the top triple machined a bit or buy a new one for the conversion and make some shims for the lowers.
Quote from: Mendo Dave on January 17, 2013, 07:31:06 PM
yup . . . done my reading. . .  if I were to do it I would get a new front end . .  speedymoto 53/53, if I did it . . .
well, it was a pleasure been here with you all here today ..  . see ya tomorrow . ..
Night Carlos.
There's a skunk outside.
