Down to 31 now.  Only @ 5" today.  Supposed to be stopping by @ 6:30.  Far from the Ft+ that was predicted.
Sorry Carlos, can't answer your question.
Randimus Maximus
Quote from: Bick on March 09, 2013, 02:58:32 PM
I'm no meteorologist (and no, I didn't sleep at a Holiday Inn Express last night), but I'd say we are getting very good precipitation from this storm.
The accumulation would probably be higher if the snow weren't as wet & heavy.
The ground was also quite warm, so it is actually melting from the bottom.  There's a fair amount of runoff in the curbs & gutters around town.
evening...
they can make the beast with two backs with the time all they want...
on a good day I'll wake up. ;D
we all will . . could be an hour late, but, we will . . .
The temp sensor on your bike is a coil spring that expands with heat. On the end of the spring is a pointer that meets different contacts (two at a time) each two produce a different tone much like a telephone. That signal is sent by wire to the gauge where a processor inturperets the tone ( there are 786 distict tones) and displays the corresponding number on the digital display. It also sends that signal to the ECU so that it knows the incoming air temp.
The sensor for the water temp works the same way but instead of sound it produces different shades of rose color and instead of a spring there is a beetle that scrambles across a little treadmill faster and faster as the temp rises. I think those are the same part number.
;D
Quote from: Mendo Dave on March 09, 2013, 04:51:02 PM
;D
doode, too complicated for dieses auslaender . . .
Quote from: Darkmonster620 on March 09, 2013, 02:50:21 PM
hello, still about 33°C/93°F . . .
can someone chime in, is the temp sensor in the 998 a Positive or negative coefficient?
pm the vet...
he may laugh at you. ;D
Quote from: ducpainter on March 09, 2013, 04:57:05 PM
pm the vet...
thanks . . .will do with a copy of your suggestion
Quote from: Darkmonster620 on March 09, 2013, 05:00:11 PM
you realize that is license for tooling... ;D
on second thought...email is better
evening
temperature sensors work by measuring the spin of the fire electron that is encased in a golden bulb inside a silk sock that is wetted by the tears of a hungry child
do these things have any bacon at all?
Quote from: Darkmonster620 on March 09, 2013, 05:28:45 PM
Bacon bits are what keep the beetle alive.
you're thinking of a barometer
baro = sanskrit for pig
since the ancient Sumerians believed that atmospheric pressure came from the pig god Baros pressing his holy flesh down upon us, the barometer went into early use to measure this a small piece of bacon is placed inside each one to this day
