Sun is well and truly over the hills here....
and still hard to tell  ;D
Sun has peeked it's head over the top and it appears that it will be a day. :P
Business as usual then  [thumbsup]
Good.
Anything you're planning on doing with this emerging day of yours?
I'm entering into uncharted territory.
I'm going to start running ducting for the HRV....
and try to maintain access to the service door with out ending up with too much of a Rube Goldberg looking affair.
HRV?
Heating  ??  Ventilation.
I say get Harry Tuttle in to give you a hand  [thumbsup]
Quote from: ungeheuer on August 21, 2013, 04:32:48 AM
HRV?
Tuttle Heating Engineer at your service!
The vid is blocked in the US... [roll] I could use the help.  [laugh]
Heat Recovery Ventilator.
It has been discovered that when you build a house that is as tight as a bull's ass that air exchange is critical to prevent mold.
This appliance passes the two air streams, fresh intake and stale exhaust, through a heat exchanger to recover up to 75% of the heat. It will run 24/7 when the windows are closed in the winter. I may have to get creative controls to make it work in the summer when windows are open and we need ventilation in a bath or kitchen to remove excess humidity...or I could just let it run all the time.
Central Services must've blocked the first Tuttle video, I edited the video with alternative.. hopefully that one works...
So the HRV requires a fan running for the duration?
Quote from: ungeheuer on August 21, 2013, 04:52:48 AM
Unfortunately it does. The fan will run on low speed. The system includes devices to allow more air flow, when required, without increasing fan speed.
Theory is the saved heating costs more than offset the added electricity cost. It has been proven in Europe where they build 'Passive Houses'. Unfortunately our climate doesn't really support the 'Passive House' theory, but elements of the design make sense.
If the engineer in you wants...I can provide a link to the specs of the unit. :-*
Quote from: ducpainter on August 21, 2013, 05:00:15 AM
If you can be bothered, I'd be interested to take a look, sure.
I gotta change the email address associated with my DMF membership to one I actually check occasionally  ;)
Quote from: ungeheuer on August 21, 2013, 05:35:10 AM
I could have dug up the other one...
but that would be too logical...illogical was more expedient. ;D
Alright, its that time again.
Later Nater, have that day of yours  [thumbsup]
Quote from: Little Monkey Toes on August 20, 2013, 07:40:35 PM
All packed and clean sheets on the bed. Off to Kingston tomorrow morning to teach for 3 days. 32 students. Day one is only the morning half so I will have time to explore the area. I will be staying in the company dormitory! I hope the coffee is good.
Lucy has a sitter coming. I was not sure what to pay her. Anyone have a sitter come stay with pets?
The going price around here is $15-$20 with plenty of food in the house.
