GOOD FIRST DAY OF VACATION MORNING . . .
15 days . . .untill the 30th . . ..
tomorrow untill the 24th I will be in Miami
Not much vacation for you in Miami... :-\
Is not really vaca, got to look for an ALF for my grandmother, she cant live alone
GK
Quote from: Needle99 on September 16, 2014, 03:36:02 AM
Evening Gk..
Will the primer blister under high temp you reckon?
At least I think it is an easy fix. Shiny new carbon open clutch cover.  ;D
I wouldn't go open cover, but full carbon I could ponder a little more!
I guess if it does blister, I could just take the cover back to bare metal and start again. The paint would probably grab the metal okay, as I think it's self priming.
I went primer this time, because I wanted a decent surface for the silver to grab. I guess I was just in a bit of a hurry! Lol!
2001 Ducati  Monster 900S ie
Gone but not forgotten!
GK
DP, Carlos!
Hope all goes well in Miami.
Needle99
Would not think the clutch cover would get super hot.
Happy holidays Carlos.
Evening Nate...  [evil]
Evening ducatters.
I need some DMF wisdom...  my DR wont start  :-\
It will bump start fine, but pushing the starter button generates nothing more than "click"
The "click" is coming from the starter solenoid.
12v to the solenoid...
12v to the starter motor from the solenoid when the starter button is pressed..
starter ground is good..
I diagnosed cactus starer brushes.  Pulled the motor apart... replaced the original (perfectly good looking brushes)... reassembled.
"click"  [bang]
This is the second episode of "click".  First time around (a good while ago)....  "click" went away all by itself  :-\  Although the common DR starter motor "rooster squawk" remained.  I bought new motor brushes back then.... but of course did nothing with em until now.
It has to be a make the beast with two backsed starter motor IMO.
Or what am I missing??
Needle99
Hey Ung...
Just missing a working starter.
I got nuttin...
Do you have an ammeter of high enough capacity to test starter draw?
It's possible the contacts in the solenoid will pass 12v, but not the amperage required to turn the motor.
In other words...
I suspect the solenoid.
GK
I'm no help Ung, sorry! I know 1/10 of bugger all about electrics!
If you jumped the solenoid, then it's either the cable or the starter.
GK
