It could be worse, you could be studying the minutiae of the fascinating world of insurance until 04:30.
Now there's 'yawn'.
Quote from: ungeheuer on June 18, 2016, 04:22:17 AM
It could be worse, you could be studying the minutiae of the fascinating world of insurance.
No worries about that happening. ;D
On another note...
why does GPS distort the 'moving' times when steep grades are involved?
Because you move more slowly or more fastly, depending on the upness or downheit of the inclination of the grade.
Of that, I have no doubt.
I understand we move slower on steep grades...of that there is no doubt.
What criteria for 'moving' does GPS use?
On yesterday's hike it had us stationary for almost 3 hours. I can assure you that was not the case.
Good morning  [coffee]
Quote from: ungeheuer on June 18, 2016, 04:32:31 AM
Particularly if you roll down hill  :P
You hiking under forest canopy?
My Spot Tracker 'loses' me when I'm out riding the DR under substantial tree coverage... finds me again when I re-emerge... and then 'fills in the gaps'...
Quote from: ducpainter on June 18, 2016, 04:43:00 AM
based on your movement it has calculated your age and assumes you to be dead so therefore immobile
Yeah...the canopy is kinda dense.
I figured since it was registering the whole time it could see us.
Maybe that isn't the case.
I'll check it in open ground to see if it's better.
Quote from: lethe on June 18, 2016, 04:55:53 AM
I was afraid of that.
or you could go with any number of popular conspiracy theory to explain it away  [laugh]
Quote from: howie on June 18, 2016, 04:43:50 AM
Rolling down this...
IMAG0139 by nh_painter, on Flickr
would hurt.
Quote from: ducpainter on June 18, 2016, 04:57:43 AM
... GPS's satellites can't see you.  So the calculation is that you were at your last reported location (for 3 hours).
Until you magically appear once again.
Agent Orange will fix the issue.
Quote from: ungeheuer on June 18, 2016, 05:16:05 AM
How does it map the route in real time if it can't see us? It's not like we're on highways.
morning . . .
nice fresh carefe full of kotowa geisha coffee . . .
Quote from: ducpainter on June 18, 2016, 05:26:41 AM
Not sure.... but I think it maybe it downloads the map of your intended route prior to commencement of the trip....  but calculates your 'real time' progress from the actual reported position of your GPS.... and then makes point-to-point assumptions based on the only actual data received.
Quote from: DarkMonster620 on June 18, 2016, 05:32:40 AM
morning . . .
Coz the Japanese are famous for coffee  [thumbsup]
