Oldfisti
Quote from: ungeheuer on June 24, 2016, 04:30:11 AM
You're gonna make me google it.  Aren't you.
Ground Fault Circuit Interrupter.  For use in wet locations so you don't get electromocuted.
Quote from: Oldfisti on June 24, 2016, 04:27:36 AM
Hello Howie!
I'm hoping the pool issue is just a random tripping of the GFI.  You said it has been a little cranky as of late?
The rotor has been sticking from debris getting into the pump, I think. I should drain it down and disassemble it, but for now I just reach down in and give it a little spin and it comes out of it...until I clean the filter again and it acts up.
Here you go... http://bfy.tw/6Qpe
Quote from: Oldfisti on June 24, 2016, 04:33:29 AM
That's not how you do it Bill. ;D
Oldfisti
Steve I'm sure you guys use something similar.  I assume it has some strange name down under so you can be "different".
Quote from: ducpainter on June 24, 2016, 04:36:04 AM
Aahhh...  [thumbsup]
RCD.
Speak English for make the beast with two backss sake  [laugh]
Oldfisti
[laugh]   Sorry.  I like your way much better.
I'm gonna go take a quick look...brb.
..just stick a 4" nail in the....
[popcorn]
All set...
The manufacturer's lawyer made them install a GFCI in the cord, as well as the electrical inspector making me install one at the outlet, so it's so safe it barely works. [thumbsup]
The GFCI in the cord had tripped. ;D
Oldfisti
So the GFCI has it's own GFCI.
Reminds me of something I heard at a house party once.  In a carpeted room, there was a throw rug on top of an area rug.  Husband says to wife... "Hey honey, I think we need some more rugs for our rugs for our rugs!"
Quote from: ungeheuer on June 24, 2016, 04:50:25 AM
Why?
WTFK? ;D
I have it hanging from a ladder to keep it off the ground, and it had fallen. Perhaps the plug moved enough when it landed to signal a voltage change.
I don't really care to be honest.
Quote from: Oldfisti on June 24, 2016, 04:57:59 AM
All outside outlets are supposed to be GFCI protected, so that's what I did.
The manufacturer doesn't need the liability of someone running an extension cord from a non protected outlet so they put one in there.
Belt and suspenders. [roll]
Quote from: ungeheuer on June 24, 2016, 05:03:07 AM
tsk..
Americans  [roll]
;D
Is this a comment on belt and suspenders...or not caring? [laugh]
