any other gear will be too aggresive
Quote from: 1.21GW on January 06, 2017, 07:02:58 AM
How do you jump a moto w a dead battery using a car battery?  Is it safe?
Assuming they're both 12volts, it should be fine.
Quote from: Satellite smithy on January 06, 2017, 07:24:27 AM
The push will work too.
1.21GW
Ok. Thanks all. Will give it a try.
Don't have the jump vehicle running.
You may want to look into a spare/replacement battery. I'm not sure if the Li batteries will fully recharge from the bikes alternator.
I can't mentally come up with a good plans to expand this garage without having to redo the entire (new) roof and three of the walls.
Maybe I should just call it a tractor shed and build something new.
Quote from: Satellite smithy on January 06, 2017, 10:17:05 AM
Maybe a trip to the zoning board to see what your options are as far as adding a building?
and go as big as possible like something the size of a Walmart because no matter how big you go it'll never be big enough.
I'm zoned agricultural. I spoke to them and they were pretty clear as long as it was 30 feet from the property line, they were happy.
I was considering a pole barn off to the side, or maybe a prefab. Having it tossed up in a week sounds okay.
Quote from: lethe on January 06, 2017, 10:40:18 AM
:D
I want to be able to heat it.
Quote from: Satellite smithy on January 06, 2017, 10:46:50 AM
forgot that you became a weak man who needs comfort while out west
It's that global hardening. It started sometime in my thirties.
1.21GW
Quote from: ducpainter on January 06, 2017, 07:44:55 AM
Thanks all for the quick replies
Running start just wouldn't turnover. But eventually found a guy w a car and some cables.
Now at the beach enjoying a very very cold cerveza. All is right!
Someone's gonna get a package in the mail!  [evil]
