It might, but, I figure I'll give it a try anyway.
It might not. I ran a Fisher (stove) with an 8" stack through a 6" thimble into an 8" flue for years without issue. I had a flue damper too.
The last one of these I had came with the option of a 6" or 8" adapter out of the fireplace-I figure I'm just moving it higher.
At lest it's a straight shot up.  :P
No wonder you have no interest in changing it. ;D
I really dislike climbing on steep icy roofs for some reason.
It's still too small. I can't think of a real good way to expand without rebuilding three walls and a roof, which seems a waste.
Ideally it would expand to cover where that Jeep is parked, and be 10' deeper.
It's going to be difficult to do that with that structure.
Sort of my thoughts.
I don't want a ton of buildings out back, and that's likely the best spot.
I did debate moving this one to the front.
Quote from: Satellite smithy on January 29, 2017, 07:16:30 AM
It really isn't big enough to bother with. The cost to move it vs. building another... ???
Unless you do it yourself. :P
I've moved a few buildings.
Can't say I every enjoyed it.
I could build behind it and it'd be fairly out of sight, but I'd have to clear a bunch of trees.
Quote from: Satellite smithy on January 29, 2017, 07:22:27 AM
I moved that screen house to where it is. It fell off the trailer and rolled onto its side. ;D
I think I'd get over the attachment to that little shed and build a real shop where it stands. I assume there's already power? 240V?
Just 110, but there's a good amount of spare capacity in the house now that we went from two electric dryers to one gas.
I wouldn't say attachment so much, but it is new, and I could use a tractor shed.
Quote from: Satellite smithy on January 29, 2017, 07:30:23 AM
why were there two dryers?
previous owner had a pile of kids?
