Good luck with fate Randy.
Went wine tasting with the neighbor tonight. Then we grilled steak.
Now home finishing up an open bottle [wine]
morning
Quote from: Randimus Maximus on March 31, 2017, 08:28:45 PM
Overcast & rainy here in paradise.
Thankfully.
I've been at home for 7 straight days, with 3 more coming.   :o :o
A trip to TX next week, which may determine my short term fate.
Life is a merry-go-round.
Actually...life is a carnival. It's in the book.
Quote from: ducpainter on April 01, 2017, 04:50:25 AM
How's the water holding up?
2 days straight . . .
now some intelligent donkey has proposed that we replace the pvc 4" main feeders to metal and then replace the 1" also with metal . . . for some weird reason I had a quotation from a few days ago that a shop asked me to perform since they want to replace the whole shop/working bays air/water distribution[all galvanised steel so must be taken down] and I told them that if we have in the maintenance bank account about $30K we can do it . . . it seems that the engineer/architect that desing this joint, for some weird reason used a 4"-1" system . . . . 4" run alonside the sidewalks feeding the 1" that feed the houses so we have aprox 3kms[2mls] of "mains" this donkey plans on replacing with metal and the gov here has banned the use of iron water piping . . .so, we could only potentially use SS and the quoted $30K is only for the cost of the 4"and 1" not counting the couplings and thread cutting . . . I am doing some investigating about installing an underground or above ground water reserve tank . . . for 2 days we[missus, dogs and me] need 100gls aprox between cooking/showering/flushing/drinking water so, was thinking a 6000liter tank, that could last up to 15~20 days if we were very very conservative
Galvanized pipe is bad.
You can get by with far less than 100 gals/day if you have to. We waste a lot of water.
Quote from: ducpainter on April 01, 2017, 05:24:03 AM
yes, on both cases . . . I can "shower" with about 5gls if I forego my medicated face wash treatment for psoriasis that is a 3 step thing . . . each flush is about 1.5gl and to cook pasta I need about 1gl in the pot . . . meat and other stuff, I have a grill and a smoker/grill and usually stock on paper plates and plastic forks/spoons . . . 100gls would be short if stepson is at home
I have a lot to do but shockingly don't feel like, what ever to do?  ???
Quote from: ducpainter on April 01, 2017, 06:11:51 AM
Watch it snow.
I'd have to come over your place to do that.
The Mustang will be a good choice right?
Quote from: lethe on April 01, 2017, 06:16:24 AM
Might get hung up in the ruts in the driveway, but otherwise...
what could go wrong? :P
It's a good day to stay put if you're here. Let the road crews do their thing, and it will be a distant memory in a month.
Quote from: ducpainter on April 01, 2017, 06:33:39 AM
ground clearance even in stock form seems like it would be problematic especially at the front splitter. Might plow pretty good.
