Quote from: Monsterlover on November 14, 2010, 08:24:07 AM
[clap]
That is an absolutely awesome idea/mental image
[laugh]
It's the way I would've built a castle if I lived back in medieval times.
"Go ahead and breach my outer walls, I dare you!"
Go through a hell of a lot of wood in the furnaces though.  :P
I heard on the radio that they caught the guy!
break again, it's a tough job having a house that someone built out of petrified wood
petrified may be an advantage over rotted.
Quote from: humorless dp on November 14, 2010, 12:27:45 PM
still sucks when something you're drilling through is about a foot thick
Quote from: humorless dp on November 14, 2010, 12:47:34 PM
Is it overhead?  [evil]
from the side, where the dishroom is, is an old addition. So basically going through what was at one time an outside wall. I did also do a few overhead ones for dropping wires down into the walls.
Quote from: lethe on November 14, 2010, 02:44:15 PM
When I was a wire monkey we did a reno on an early 1900s brick building they turned into apartments.
I spent days drilling 2x, 4x, 6x 12 hemlock to run pipe for each apartment's panel feed. The holes had to be accurate and all of them were overhead. I got to use a hole hawg waaaay more than I wanted.
I feel for you.
At least in my case, I can stop if I want and no one is going to say anything about it.
I eventually wanted to stop...
and did.  ;)
with all the drilling I did I could tell you stories... [laugh]
