Quote from: ducpainter on July 23, 2011, 05:17:19 AM
being basically clueless would normally be calming.
not the case in this situation. [laugh]
What could go wrong?  8)
Quote from: lethe on July 23, 2011, 05:18:31 AM
when you find out what I'm building you'll understand. :P
Quote from: ducpainter on July 23, 2011, 05:21:04 AM
I have an idea and that was sarcastic optimism
Quote from: lethe on July 23, 2011, 05:25:33 AM
Murphy lives here
he's everywhere
Quote from: Monsterlover on July 23, 2011, 05:37:46 AM
pretty neat
what's the problem?
A single fastener penetration through the sheathing can ruin the envelope.
I've been planning and thinking about this for over a year.
I've dreamed up lot's of things to go wrong. :P
Quote from: ducpainter on July 23, 2011, 05:42:04 AM
he's everywhere
A single fastener penetration through the sheathing can ruin the envee been planning and thinking about this for over a year.
how would you even know if that happened?
Quote from: Monsterlover on July 23, 2011, 05:45:53 AM
If you don't find it and deal with it before you seal up the  walls...
when the wall rots and the house gets moldy...you know.
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: Dan on July 23, 2011, 06:07:51 AM
WHat are you using for siding?
I'm thinking about Hardy plank or some non wood product spaced off the foam with strapping. The top and bottom will have insect screening to keep the buggers from nesting behind.
That eliminates sheathing penetrations and ventilates behind the siding which should make whatever I use last much longer.
