I discovered a new expense today.
The trans oil check bolt on the 450 is totally stripped and someone glued it in place with rtv [bang]
I could A) grease up a drill and tap and tap it larger
Or B) do the right thing and drain the engine oil, trans oil, coolant, pull the clutch,  water pump, kick start lever and right side case cover so I can repair it by either tapping it larger or with a helicoil.
Battery is also toast, which I knew about.
I'd glue it back in and fix it this winter
Quote from: Monsterlover on November 13, 2011, 03:52:00 PM
get to ride it though?
Ceiling going up at a slow pace in the dining room
DesmoDiva
EveNing guys.   [wine]
Gotta love rtv!   ;D
B made his yummy short ribs for dinner.   [drool]  I made smashed taters and aperagas as sides.
We picked up a great bottle of CA Cab, rated 93pt for $11.99.  It's damn tasty.
Also got a turkey for thanksgiving.  You think 12lbs is big enough for two?   [roll]
Just finished up with class prep for tomorrow.   [thumbsup]
Ceiling looks great, mike!
What type of flooring, dp?
'01 ST4 Yellow
'02 ST4s Yellow
Brazilian cherry.
Stuff is hard as a brick.
I don't think even destructo force will be able to scratch it.
Yeah it does Mike. [thumbsup]
Hi diva
Bonus points if you know what rtv stands for without using the net to look it up ;)
Did not ride the 450 yet. The only way it would start is on the car charger set to 50amp start.
The idle is way off too. Think glowing head pipe.
DesmoDiva
Nice!!
Went for the good stuff.   [thumbsup]   Good thing its just the hallway.
What are the bedrooms going to have for flooring?
rtv=liquid gasket stuff, B prefers the black.
'01 ST4 Yellow
'02 ST4s Yellow
I like the black stuff too
RTV= room temperature vulcanizing
Quote from: DesmoDiva on November 13, 2011, 03:59:03 PM
Quote from: ducpainter on November 13, 2011, 04:03:20 PM
Thanks
Brazilian cherry.
He'll find a way
Quote from: Monsterlover on November 13, 2011, 04:04:54 PM
doesn't have a backup kickstart?
DesmoDiva
I was close...(r) than 80% of the female population would guess.   ;)
'01 ST4 Yellow
'02 ST4s Yellow
Close enough. :)
Btw short ribs sound awesome [drool]
Mike- couldn't get it going on the kick lever.
Quote from: Monsterlover on November 13, 2011, 04:20:27 PM
Close enough. :)
I actually haven't even tried mine, left side kick feels weird
I got a smoking deal on a small amount of extra that a friend and DMFer had left over from building his house.
I think there'll be enough for the stair landing too. ;D
Quote from: lethe on November 13, 2011, 04:15:00 PM
He'll find a way
He is talented that way. ;)
Quote from: lethe on November 13, 2011, 04:22:19 PM
I actually haven't even tried mine, left side lick feels weird
Mines on the right
