O-ring chain lube, what are you using?
Started by Grappa, May 14, 2008, 01:21:37 PM
sydmonster
Quote from: Pakhan on May 14, 2008, 01:35:24 PM
Maxima chain wax
+4 - Chris
ps, the cleaning is important. So is applying it when chain has some heat (ie after a ride), spray on, then wipe off all excess and clean sprockets while your there. Remove front sprocket cover and clean there well.
...Sydmonster - down under
Contact me about your mods and what Street Cred Points you can earn!
I'm a Motorex fan.  Notice the lack of consensus.  Just use what works for you.
Ddan
Another one for Motorex.  Apply it to a warm chain, let it sit and wipe of the excess.  Stays reasonably clean, minimal fling.
Ducati Monster Forum at
www.ducatimonsterforum.org
Xiphias
Hi-ho-hi-ho....its off to the track I go.................
ScottRNelson
DuPont Teflon Multi-Use Lubricant
I just sprayed some on my chain last night.
I've been using it long enough to go through the full life of one chain.  The chain lasted 13,000 miles, which is pretty typical for me, and about the same as with Maxima Chain wax.  It still looked beautiful, but had stretched unevenly so that there were tight spots and loose spots.  It might have been adjusted a bit too tight at one time or something.
I like the Teflon stuff because it attracts less dirt, has less stuff flinging off onto my wheel (although Maxima Chain wax was pretty good in that area too), and smells nicer when you apply it.  Plus it is a great lubricant for a lot of other things that you can't use Chain Wax on.
As far as I know, about the only place you can buy it is at Lowe's.
scooby
Quote from: EEL on May 14, 2008, 01:43:09 PM
Dupont Teflon Multipurpose lubricant. Has worked great so far..
+ another...
What would ScoobyDoo?
hiero
Quote from: scooby on May 15, 2008, 06:30:34 AM
+ another...
+1 more, although I recently picked up the liquid bottle form and it's pretty nice not getting overspray over everything... didn't pick it up on purpose, but have a bunch of bottles of it now that I gotta get through...
2000 Monster 750
1999 748
YELLOW!!
scooby
Quote from: hiero on May 15, 2008, 06:36:02 AM
although I recently picked up the liquid bottle form <snip>
Yup, I bought a small liquid bottle to keep in my tank bag for longer trips (+500 miles) so I can lube up up  en route...
erkishhorde
So for you guys using the Dupont, what do you use as a cleaner? Say if I were to switch, I'd likely clean off the old chain wax before putting on the Dupont. Thing with Maxima is that I use it as a cleaner and a lube. I'm not terribly fond of the idea of hosing my chain down with WD40 like some people say. I'm one of the paranoid types that thinks it could get to the O-ring inside and eat it up. So what else could I use?
ScottRNelson
I use kerosene.  It works much better than WD-40 and is good for cleaning other things as well.  It's safe for chain O-rings.  Plus if your lights go out, you can put it in one of those old "oil" lamps and burn it to provide light.
I bought about two gallons at the local Orchard Supply Hardware store, which should last me twenty or thirty years.
hiero
Quote from: ScottRNelson on May 15, 2008, 08:27:08 AM
+1 kerosene's great for all kinds of grease clean up on top of being great on the chain...
2000 Monster 750
1999 748
YELLOW!!
scooby
Quote from: hiero on May 15, 2008, 09:08:56 AM
+1; and its cheap as shit too...  [laugh]
Grappa
+1 more for kerosene for cleaning.  Works great, but eats up my plastic cleaning tools.
Ahh... but the servant waits, while the master baits.
Sometimes Aloha means Goodbye.
Ddan
